Old 10-25-2008, 09:55 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
No electric shock exit
I've found the most effective way to prevent the electric shock when exiting the car is to rest one knuckle on the door glass as I open the door and get out. Use the right hand.
Sorry, no photos cause I figured this DIY is self-explanatory.
Old 10-25-2008, 10:05 PM   #2
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
I was once told by a tech at Toyota that ..... shocks when you exit can be an indicator of the charging system going bad.
I don't know how true it is but I do not get shocked on mine. Maybe in the dead of winter when the air is much drier it could change.
Old 10-25-2008, 10:46 PM   #3
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
The relative humidity has been extremely low in southern California for this last week. It's been running 5-10% lately, thus we're getting a lot of static shocks (and wildfires).
Thanks for the tip, I'm going to try it.
Reddog99 is offline   Reply With Quote
Old 10-26-2008, 12:52 AM   #4
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
with the colder weather and lower humidity i've been getting shocked more recently too. As long as you make contact with any metal body panel as you are getting off your seat, you will transfer the energy through that contact and wont be shocked.
I got used to either holding onto the chassis door frame or top of the door as I get out of the car.
taKuto is offline   Reply With Quote
Center exit exhaust Turbo&Auto Performance Modifications 5 06-25-2007 02:04 PM
Rear shock absorbers problem Yaris PTY-507 Central and South America 1 10-16-2006 04:07 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
Exhaust exit jcove Cosmetic Modifications (Exterior/Interior) 17 05-09-2006 06:31 PM
