Old 10-26-2008, 09:37 AM   #1
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Engine torque damper, anybody have one?
I don't know why, but I'm really intrigued by this thing. Does it actually cut down on vibrations from the engine? Is it worth it to install on an automatic liftback?
Old 10-26-2008, 01:56 PM   #2
ddongbap
It doesn't cut down on vibrations. It might even make it worse. It just stops your engine from rolling around in the bay, so you can put all the torque down to the wheels, instead of losing some to the motor mounts.
Old 10-26-2008, 02:29 PM   #3
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
its worth it but it does create more vibrations since you are making the motor more solid i have one on my tc and it makes a difference but the vibration is noticeable and you notice the difference with the torque its more instant then before
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-26-2008, 05:12 PM   #4
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
It will make you car vibrate even more but it isn't worth it to throw on an automatic IMO.
Old 10-26-2008, 09:34 PM   #5
ddongbap
Torque is torque, it'll still help an automatic.
Old 10-26-2008, 09:36 PM   #6
dacourier
dacourier's Avatar
Drives: Black Sand Lift Back
Garm aka Caliyaris has them. Go onto microimage and you should be able to contact them and get one.
Clinging to my guns and religion down here in the south. Come and take them!
dacourier is offline   Reply With Quote
Old 10-27-2008, 12:07 AM   #7
jronald
jronald's Avatar
Drives: Black NCP91R
I custom-made it from Bilstein engine-damper, installed it to my A/T Yaris and it works nicely..
especially when I do engine-brake.
jronald is offline   Reply With Quote
Old 06-25-2009, 02:14 PM   #8
lammy29
anyone got this on manual? worth the money?
lammy29 is offline   Reply With Quote
Old 06-25-2009, 05:58 PM   #9
2bad4u
Drives: 06 Toyota Vitz RS
Yes I have a torque damper and it does give you a bit more kick in rapid shifting with less motor movement but a lot and I mean a lot more vibrations at idle when it is more noticeable.
2bad4u is offline   Reply With Quote
Old 06-25-2009, 09:35 PM   #10
kargoboy
kargoboy's Avatar
Drives: '07 Yaris Sedan/'03 Protege
ETDs are a good idea. Bolt-on power adders aren't the only way to get more to the wheels,
deducting parasitic loss is just as important.
And it'll save your motor mounts too, esp. if you have a heavy foot.
kargoboy is offline   Reply With Quote
Old 06-25-2009, 10:33 PM   #11
I have red, grey and blue in stock:
http://shop.microimageonline.com/pro...2&productId=13
Old 06-26-2009, 12:42 AM   #12
llimonce
Drives: yaris sedan
that increases vibration at iddle ??
llimonce is offline   Reply With Quote
Old 06-29-2009, 11:06 PM   #13
josevenezolano
Drives: Toyota Yaris HB 2008
Yes, It will but just a little bit!
josevenezolano is offline   Reply With Quote
Old 06-29-2009, 11:13 PM   #14
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
i have this, but i also have a supercharger too.before i had it on, the engine would move around alot; atleast when i would rev the engine ( you can see the engine move around at the end of my video in the link in my sig). however, now that i have the torque damper, the engine doesn't go anywhere. however, i don't really notice the car idling that rough? only when the A/C is on, but that is a supercharger related mystery..
Old 06-29-2009, 11:57 PM   #15
josevenezolano
Yes, It isn't that bad. Mine has been sounding weird with my car iddle..
Old 06-30-2009, 12:22 AM   #16
YarisSedan
Drives: 08 Yaris Sedan
I been eyeing one of these for awile after i put on my nst pulley. Car jerks a bit from takeoff now since the crank pulley has been lightend. Hopeing that this will help dampen things a bit. Otherwise i probally got a broken motormount already.
Old 06-30-2009, 12:50 AM   #17
baked_limabeans
Drives: Polar White
only shows gray and red
baked_limabeans is offline   Reply With Quote
Old 06-30-2009, 01:10 AM   #18
1NZYaris1
1NZYaris1's Avatar
That's Cause Garm is color blind
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 09:33 PM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
