09-17-2011, 12:12 PM | #19 |
Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
09-17-2011, 12:14 PM | #20 | |
in the case of the A Pillars it was one layer of swimsuit material and a whole bunch of bondo / and body filler to smooth out some areas and fill it in a little bit when I apply resin, I mix the resin and the hardener in a paint tray and I apply it with a paint brush and cure it in direct sunlight |
09-17-2011, 01:40 PM | #21 |
Drives: Yaris sedan Join Date: Apr 2011
I really impressed with your work.
You can earn on it. It looks very cultured.
I like very much travel |
09-17-2011, 08:10 PM | #22 |
Roadrunner Jr.
Love me some Pre-Mitek Xtant.
What is the source you're using and how's your imaging, soundstage, and depth? Also...you CAN relocate those wiring bundles in the kicks up into the dash area for more room...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
09-17-2011, 10:19 PM | #23 | |
Not known for its SQ - but its a good all arounder with decent NAV. I did relocate the wiring blocks all the way up under the dash (about 14 inches away from where they were originally) Personally I think it ends up sounding pretty damn good considering how narrow the cabin is. The stage is high and up front - the depth is pretty good (although not always at the end of the hood like some cars I've built) At its first IASCA show (my first show in over 10 years) it got second in class SQ - (1st place was a much bigger vehicle with similar setup) once I build 6.5"s up front / add the second sub (sealed up front) and tune it, its going to sound amazing (I think) I'm kinda thinking Dayton RS28F's in the A-pillars (padded down a bit and off axis ) - ALONG with the TangBand Bamboo 3.5" (Also in the pillars - almost on axis) - and maybe even the Peerless SDS 6.5 in the kicks (rather than the TangBand underhung or the Type X). W |
09-18-2011, 08:39 AM | #24 |
Roadrunner Jr.
Well...with that said, we should have you show up at Keith McCumber's shop in Coquitlam BC next year to make a Yaris statement! You in Amateur or a Pro/Am class?
You may not need it, but on the pillars, that little white Molex plug is the antenna. That plug can be removed IIRC and the wire can be soldered. Space savings.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine Last edited by sqcomp; 09-18-2011 at 08:51 AM. |
09-18-2011, 11:22 AM | #25 | |
Drives: soarer Join Date: Feb 2011
Thanks |
09-18-2011, 11:34 AM | #26 | |
I did my A pillars recently and could not find any suitable material in stores like Canadian tire or Home Depot around. Had to use some ugly female pants that I bought at a nearby shopping mall (those were on sale for 1.99 a pair).. However, shopping for ugly femal pants in the women apparel boutique is not a pleasent experience |
09-18-2011, 03:54 PM | #27 |
Roadrunner Jr.
The coquitlam event(s) will be in the spring and summer of next year. The season is pretty much done for this year.
I'll keep you guys in the know in this section.
09-18-2011, 04:49 PM | #28 | |
09-18-2011, 10:07 PM | #29 |
09-18-2011, 10:07 PM | #30 |
09-19-2011, 08:43 AM | #31 |
toyota
wow
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
09-21-2011, 01:36 AM | #32 |
Very nice install! but please don't call your install "amateur(ish)" looks like work from Pros!
Looks really good! D.
. My system may not blow your ears, but it will sweeten your senses. CLA 250, 4MATIC |
09-21-2011, 08:50 AM | #33 | |
There was a bunch of stuff that I felt I could have done better The next iteration will have nicer kick panels and maybe two-way a-pillars Will |
03-18-2013, 05:11 PM | #34 |
Drives: 3dr Lftback (meteorite) Manual Join Date: Apr 2010
Awesome. Thanks for posting!
03-19-2013, 07:28 PM | #35 |
Roadrunner Jr.
Love the Pre-Mitek Xtants!
03-19-2013, 10:18 PM | #36 |
Drives: '10 Yaris LB Polar White Join Date: Oct 2010
Outstanding!!!!!!!!!!!!!!!!
If only I had the skill and patience to do the work you completed. |
Similar Threads | ||||
sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-04-2011 11:56 PM |
