10-05-2012, 10:14 AM | #1 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Speedometer Calibration / DeMetrification
If you are wondering what the heck DeMetrification is, it is my new term for modifying a device intended to display in Metric units to display in English units.
Last month I finally figured out how to reprogram the odometer on our instrument cluster to allow for easier swapping of clusters (http://www.yarisworld.com/forums/showthread.php?t=41461). The most common reason for wanting to swap clusters it to gain the OEM tachometer (for those in the US with 2009 or older manual transmission, non-S package Yaris, which did not have the tach). The problem is that S package MT liftbacks were not very common, so few clusters from them are available on eBay or from junkyards. On the other hand, all MT Canadian liftbacks had tachometer equipped clusters, so Kmh clusters are very easy to find for reasonable prices (typically under $100). The problem, for those south of the border, with running a Canadian Kmh cluster is that (besides the large-number primary speed display being in Kmh) the odometer increments in kilometers. After driving around for a couple day with an oscilloscope attached to the speed sensor input to the cluster, I was able to develop a device which measures the pulse width of the signal and replicates that signal, with the pulse width proportionally adjusted to allow the cluster to display in MPH as well as increment the odometer in miles. I also added a feature, which allows the user to make a fine adjustment to calibrate the speedometer to a GPS to account for variations in tire diameter, etc. The device has four wires that connect to the right side connector on the speedometer (power, ground, speed signal in, and speedometer out). Normally the speed signal goes into the cluster and then out of the cluster (unmodified) to the ECM. In my initial testing I found that feeding the modified signal to the ECM on my automatic transmission Yaris caused some really odd shift point changes (since the ECM controls the AT). To eliminate this I simply disconnected the ECM output wire from the cluster and connected it to the input to the cluster (so that it sees the unmodified signal). Note that once connected and calibrated, this device would not be mounted to the dash, but would simply be tucked under the instrument cluster. Here is video of it in action. I apologize for the shakiness from my headrest mount. http://youtu.be/KkUOgEvTYAY
10-05-2012, 10:34 AM | #2 |
any way you could post some pictures for us guys that can't see youtube at work? (yea, that part about my job really sucks)
amazing what you have figured out with the yaris. you're awesome |
10-05-2012, 10:47 AM | #3 | |
Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
There are absolutely no Yaris in Canada that did not have a tach.
10-05-2012, 10:51 AM | #4 | |
Here are a couple of snaps from the video. Basically, with a flick of a switch the needle moves from showing kmh to MPH on the large numbers: Before.jpg After.jpg
10-05-2012, 12:03 PM | #5 |
that's an awesome little thing there. I assume you are going to be selling these?
10-05-2012, 01:25 PM | #6 |
I can definitely build some up for those interested. The ideal way to do it is to buy the cluster, and ship it to me for odo correction as well.
10-05-2012, 02:05 PM | #7 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
The only downside to that would be that if we drive the cars while you have it, the mileage would be off (granted, not by much).
How much would you charge for the service on top of shipping? (I'm likely to do this ;0) )
10-05-2012, 04:42 PM | #8 |
2ZR swap. DO IT! Ask how!
Wow, I had imagined doing something like this for my microcontroller class project this semester. Well, the speedo correction for tire sizes, anyway.
CTScott scores again! |
10-05-2012, 09:19 PM | #9 | |
What family of micros do they have you working with?
10-06-2012, 10:20 AM | #10 |
Drives: 2008 yaris hb Join Date: Mar 2011
I have the cluster, tell me where to send it
10-06-2012, 10:59 AM | #11 | |
Drives: '08 Yaris LB Join Date: Jan 2012
I've noticed the same thing on AT corollas. I was kind of a bit shocked when I saw old american corollas and tercels with MT's and no tach too! |
10-06-2012, 11:09 AM | #12 | |
Anywho, amazing work, again CTScott!
10-06-2012, 02:07 PM | #13 | ||
10-06-2012, 03:53 PM | #14 |
We should just coordinate a day where you can come down and we'll install it.
10-06-2012, 03:56 PM | #15 | |
I used a PIC 18F series, as I needed the extra processing power. I exclusively work with PICs, since that is also what I use for work projects.
10-06-2012, 04:08 PM | #16 |
If Its Not Blown It Sucks
Holy crap...I haven't heard 68HC11 uttered in over 15 years. My senior project was an open loop EFI for a lawnmower. It worked extremely well but would have doubled the cost of the mower. Neat stuff Scott.
P.S. Still working on the S/C from the Milennia for my Yaris. |
10-06-2012, 04:13 PM | #17 |
Maybe another install day, as ong as it is on a sunday I am good to go
10-06-2012, 09:00 PM | #18 | |
Did you actually purchase the S/C?
Tags |
calibrate, speedometer, tach, tachometer |
Similar Threads | ||||
Speedometer calibration | Stiv | DIY / Maintenance / Service | 2 | 04-20-2020 08:54 PM |
Speedometer Accuracy? | YarisPete | DIY / Maintenance / Service | 37 | 11-29-2013 02:00 PM |
OEM Speedometer with tachomter | Deshi Basara | DIY / Maintenance / Service | 6 | 08-21-2012 10:11 PM |
speedometer | walt101786 | Cosmetic Modifications (Exterior/Interior) | 0 | 10-09-2010 09:03 PM |
No speedometer or tachometer lights during day | cdavidhess | DIY / Maintenance / Service | 20 | 06-30-2009 10:38 AM |
