Old 05-16-2015, 12:17 PM   #1
dchippowski
Drives: 2007 Yaris manual hatchback
2007 yaris instrument cluster dead and engine won't start
Hi all,
My wife tried to start our Yaris earlier in the week and she said it was completely dead. Today, I went to look at it and found that the engine would turnover with no issues and all electrical accessories worked fine except the instrument cluster. It would not start, not even a hint of combustion. Lights,wipers, windows,climate control fan, turn signals, and hazards all work fine. The instrument cluster shows no signs of life. No clock, odometer, fuel gauge, and backlighting is non-op when the key is is "on" position. The door ajar light functions within the cluster, but nothing else I can see. I replaced the battery, checked the cables, and all the fuses I can think of to check are good. I am at a complete loss here now. It's a manual 3 door hatchback, no engine immobilizer. Any ideas? If there is a fuse I might not have checked that may be the culprit throw it out there. Thanks.
dchippowski is offline   Reply With Quote
Old 05-16-2015, 05:28 PM   #2
Check the two large fusible links that are built into the black block on the positive battery terminal.
Old 05-17-2015, 11:00 AM   #3
dchippowski
Thanks CT. Both of those links are intact and not melted.
engine, instrument cluster
The Yaris Performance Primer eTiMaGo Performance Modifications 30 01-24-2024 04:26 AM
2008 Toyota Yaris Hatchback Wouldn't Start kieranhiggins DIY / Maintenance / Service 2 05-12-2015 08:18 PM
no start: engine immobilizer random issues the_teach DIY / Maintenance / Service 4 04-13-2015 07:55 AM
2007 Yaris hatchback wrecked...odds of it getting totaled? Details inside Josh_G General Yaris / Vitz Discussion 27 12-16-2008 12:54 PM
Yaris 06 H/B Engine Cutting out problem.. Farenheit General Yaris / Vitz Discussion 3 09-14-2007 01:21 PM
