Old 04-30-2006, 08:22 PM   #1
YarisBueller
Administrator
YarisBueller's Avatar
Compilation of Yaris How-tos/DIYs
Trying to organize by category - eTiMaGo
Some might be doubled up, if there's more than one writeup on the subject!
Interior
How to remove the Backseats : http://www.yarisworld.com/forums/showthread.php?t=306
Sparco Raceseat Installation : http://www.yarisworld.com/forums/showthread.php?t=360
Install a Tachhttp://www.yarisworld.com/forums/showthread.php?t=662
Oil Pressure Gauge Install: http://www.yarisworld.com/forums/showthread.php?t=15233
30 sec Door Panel Removal - http://www.yarisworld.com/forums/showthread.php?t=2305
Remove Door Panels: http://www.yarisworld.com/forums/showthread.php?t=15011
Big Foot Mod - http://www.yarisworld.com/forums/sho...t=big+foot+mod
Center Control Knob Color Change - http://www.yarisworld.com/forums/showthread.php?t=2275&
Change Radio/Radio LCD Color - http://www.yarisworld.com/forums/showthread.php?t=2853
Change Your Gauge Cluster Color (sedan)Here - http://www.yarisworld.com/forums/showthread.php?t=2928
Interior Light Color Change: http://www.yarisworld.com/forums/showthread.php?t=9857
Paint interior panels: http://www.yarisworld.com/forums/showthread.php?t=4079
Discreet Mounting of 12v Adapter - http://www.yarisworld.com/forums/showthread.php?t=1934
Power Outlet Mod - http://www.yarisworld.com/forums/showthread.php?t=1542
Powered USB Ports: http://www.yarisworld.com/forums/showthread.php?t=9431
Replace Door Panel Fabric: http://www.yarisworld.com/forums/showthread.php?t=5991
Front Seat Modification: Increase Thigh Support: http://www.yarisworld.com/forums/showthread.php?t=9833
Clazzio Seat Cover Install: http://www.yarisworld.com/forums/showthread.php?t=11925
TRD Shift Knob Install: http://www.yarisworld.com/forums/showthread.php?t=11493
Cabin Air Filter: http://www.yarisworld.com/forums/showthread.php?t=8828
Install variable wiper control stalk: http://www.yarisworld.com/forums/showthread.php?t=15512
Electronics/Sound System/Security
How to change the Stereo headunit : http://www.yarisworld.com/forums/showthread.php?t=225
Disable Daytime running Lights : http://www.yarisworld.com/forums/showthread.php?t=894
Disable Daytime Running Lights - http://www.yarisworld.com/forums/showthread.php?t=1881
Install Grounding Kit: http://www.scionlife.com/forums/view...ight=grounding
Replacing Stock Deck: http://www.yarisworld.com/forums/showthread.php?t=556
Removing Door Speakers: http://www.yarisworld.com/forums/showthread.php?t=1718
Install HIDs - http://www.yarisworld.com/forums/sho...&postcount=114
3dr Speaker Install - http://www.yarisworld.com/forums/sho...8537#post38537
Keyless Entry Install: http://www.yarisworld.com/forums/showthread.php?t=9565
Add Remote to Factory Keyless Entry - http://www.yarisworld.com/forums/showthread.php?t=1526
Power Rear Hatch - http://www.yarisworld.com/forums/sho...t=remote+hatch
Bypass Tire Pressure Monitoring System ('08 and up): http://www.yarisworld.com/forums/showthread.php?t=11058
Braille Battery Install: http://www.yarisworld.com/forums/showthread.php?t=13719
Headlights Off with the Ignition Switch: http://www.yarisworld.com/forums/showthread.php?t=14427
Install Trombe Stebel Nautolus Horn: http://www.yarisworld.com/forums/showthread.php?t=9423
Unlink AC From Defroster: http://www.yarisworld.com/forums/showthread.php?t=10888
Engine/Exhaust/Transmission
Megan Header Install - http://www.yarisworld.com/forums/showthread.php?t=2986
NST CR-Lite pulley install: http://www.yarisworld.com/forums/showthread.php?t=3964
DIY $30 intake: http://www.yarisworld.com/forums/showthread.php?t=4392
$30 Oil Catch Can: http://www.yarisworld.com/forums/sho...9085#post79085
Install Greddy Exhaust: http://www.yarisworld.com/forums/showthread.php?t=6691
1.8L (1ZZ) Throttle Body Connector Chip Swap: http://www.yarisworld.com/forums/showthread.php?t=14672
NST Short Shift Kit Install: http://www.yarisworld.com/forums/showthread.php?t=7533
Intake Install: http://www.yarisworld.com/forums/showthread.php?t=8278
AEM Intake install: http://www.yarisworld.com/forums/showthread.php?t=9582
NST Shifter Bushings: http://www.yarisworld.com/forums/showthread.php?t=9585
Suspension/Brakes
Tanabe Spring Install : http://www.yarisworld.com/forums/showthread.php?t=1096
Spring Install: http://www.yarisworld.com/forums/showthread.php?t=15135
Megan Coilover Install: http://www.yarisworld.com/forums/showthread.php?t=9124
Strut Tower Bar Install - http://www.yarisworld.com/forums/showthread.php?t=2285
Type 1 Lower Bar Install -http://www.yarisworld.com/forums/showthread.php?t=1227
Rear Sway Bar: http://www.yarisworld.com/forums/showthread.php?t=14084
Rear Drum Brakes/Parking Brake Adjustment: http://www.yarisworld.com/forums/showthread.php?t=12333
RunStop rear Disc Brake upgrade: http://www.yarisworld.com/forums/showthread.php?t=12489
Exterior
Baking and Painting Headlightshttp://www.yarisworld.com/forums/showthread.php?t=1525
Remove Emblems Vid - http://www.yarisworld.com/forums/showthread.php?t=2679
De-badge Your Rear End - http://www.yarisworld.com/forums/showthread.php?t=938
Hatch-back Spoiler Install - http://www.yarisworld.com/forums/showthread.php?t=661
Tint/Vinyl Your Tail Lights - http://www.yarisworld.com/forums/showthread.php?t=1596
Side Market Bulb swap: http://www.yarisworld.com/forums/showthread.php?t=4106
eBay Fog Lights Install: http://www.yarisworld.com/forums/showthread.php?t=3471
Additional Fog light install info: http://www.yarisworld.com/forums/showthread.php?t=15197
Another fog light Install (ESUSE brand): http://www.yarisworld.com/forums/showthread.php?t=9473
LED Side Mirror Cover install: http://www.yarisworld.com/forums/showthread.php?t=6447
Side mirror cover and wing install: http://www.yarisworld.com/forums/showthread.php?t=9313
Sedan Spoiler Install - http://www.yarisworld.com/forums/showthread.php?t=8595
JDM RS taillight (OEM) Install: http://www.yarisworld.com/forums/showthread.php?t=7224
JDM RS taillights (replica) Install: http://www.yarisworld.com/forums/showthread.php?t=9692
Smoke (paint) Sedan headlights: http://www.yarisworld.com/forums/showthread.php?t=13521
Fixing a dent with a hairdryer: http://www.yarisworld.com/forums/showthread.php?t=13917
Install Sedan Mesh Grille: http://www.yarisworld.com/forums/showthread.php?t=12090
Install LB Halo Projector Headlights: http://www.yarisworld.com/forums/showthread.php?t=9430
Sealing the Hood: http://www.yarisworld.com/forums/showthread.php?t=10035
Mileage Improvers
Engine Grill Block - http://www.yarisworld.com/forums/showthread.php?t=8985
Misc
Custom Trunk Liner - http://www.yarisworld.com/forums/showthread.php?t=1211
Undercoating Your Inner Wheel Wells -http://www.yarisworld.com/forums/showthread.php?t=904
10 Minute Engine Bay Detail: http://www.yarisworld.com/forums/showthread.php?t=4729
Hood damper: http://www.yarisworld.com/forums/showthread.php?p=10209
DIY Hood Damper: http://www.yarisworld.com/forums/showthread.php?t=15219
Hood Insulator Install: http://www.yarisworld.com/forums/showthread.php?t=12627
Ghetto Camcorder mount: http://www.yarisworld.com/forums/showthread.php?t=2872
Low (no)-cost Camcorder mount: http://www.yarisworld.com/forums/showthread.php?t=15642
Turn off VSC and TRC (European models only): http://www.yarisworld.com/forums/showthread.php?t=12487
Wiper Cowl removal: http://www.yarisworld.com/forums/showthread.php?t=9581
Brake Cooling/Cold Air Intake ducts: http://www.yarisworld.com/forums/showthread.php?t=8333
Lower Windshield Rattle Fix: http://www.yarisworld.com/forums/showthread.php?t=9081
General Maintenance
Manual Tranny Oil Change - http://www.yarisworld.com/forums/showthread.php?t=8912
Brake Pad Change: http://yarisworld.com/forums/showthread.php?t=4530
YarisBueller is offline   Reply With Quote
Old 09-12-2009, 02:11 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I hereby open this thread for new submissions!
DIY amp wire running and radio trim removal - http://www.yarisworld.com/forums/showthread.php?t=22228
08' USDM LB Interior Light Color Change - http://www.yarisworld.com/forums/showthread.php?t=9857
Old 09-12-2009, 03:19 PM   #3
jclo3313
jclo3313's Avatar
Thanks man!
Obama Can't Gymkhana!
Old 09-13-2009, 12:12 AM   #4
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Thanks man!
No problem! Hopefully this thread will become a kick-ass wiki page soon enough.
Old 09-17-2009, 02:16 AM   #5
tk-421
tk-421's Avatar
Drives: 5D-07-LB
DIY Projector/HID (Liftback) - http://www.yarisworld.com/forums/showthread.php?t=22124
Old 09-21-2009, 01:55 PM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Squeaky Manual Transmission Quick Fix: http://www.yarisworld.com/forums/showthread.php?t=10644
Old 09-28-2009, 07:47 PM   #7
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Interior
DIY Change Your Interior Light Grey Panels to Black: http://www.yarisworld.com/forums/showthread.php?t=16160
Old 10-06-2009, 08:23 PM   #8
MGargano
Drives: 2009 Yaris Hatchback
Has anyone else noticed that the 'Install HIDs - http://www.yarisworld.com/forums/sho...&postcount=114' thread no longer works (and hasn't for a long time)?
MGargano is offline   Reply With Quote
Old 10-06-2009, 10:06 PM   #9
2bad4u
Drives: 06 Toyota Vitz RS
neither does the 1zz tb chip swap all info has been removed
2bad4u is offline   Reply With Quote
Old 10-15-2009, 06:51 PM   #10
tk-421
tk-421's Avatar
Drives: 5D-07-LB
DIY Stealth Garage Door Opener Button: http://www.yarisworld.com/forums/showthread.php?t=20330
Old 10-15-2009, 07:00 PM   #11
Black Yaris
der Zeck
Black Yaris's Avatar
you should check some of those links.... some of them are linked to deleted posts
Old 10-17-2009, 02:32 AM   #12
tomato
tomato's Avatar
^ will do
Old 10-20-2009, 08:53 AM   #13
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Exterior
Door Handle LED DIY: http://www.yarisworld.com/forums/showthread.php?t=22008
Old 12-24-2009, 11:35 PM   #14
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I just noticed that...however I was able to find this guide for installing them in the sedan (which is perfect for me). This actually applies to the projectors that Micro Image supposedly sells, though I don't see them on the site anymore.
http://www.yarisworld.com/forums/showthread.php?t=22112
Old 01-17-2012, 07:16 PM   #15
tk-421
tk-421's Avatar
Drives: 5D-07-LB
These used to be stickies until today (if someone needs them back as stickies for some reason let me know):
DIY - Liftback Intermittent Wipers via Stalk Replacement (v2.0)
DIY Cruise Control on 07-08 Yaris (step by step)
http://www.yarisworld.com/forums/showthread.php?t=21715
DIY Cruise Control FAQ (2006-2010 Yaris)
http://www.yarisworld.com/forums/showthread.php?t=25515
Resetting Service Required Light
http://www.yarisworld.com/forums/showthread.php?t=3940
DIY: Painting Engine Cover
http://www.yarisworld.com/forums/showthread.php?t=15827
DIY: Debadge/Black out Emblems
http://www.yarisworld.com/forums/showthread.php?t=9675
DIY (08' USDM LB): Interior Light Color Change
DIY - Headlights off with the Ignition Switch
Old 01-27-2012, 12:57 PM   #16
ayuhuasca
Yaris Hell
ayuhuasca's Avatar
Drives: yaris
I need the re-chip how-to please, anyone have one with pics?
I'LL KEEP MY GUNS AND MONEY, YOU KEEP YOUR "CHANGE"!
ayuhuasca is offline   Reply With Quote
Old 01-27-2012, 01:11 PM   #17
The who? Are you referring to a reflashing?
Old 01-27-2012, 01:39 PM   #18
ayuhuasca
Yaris Hell
ayuhuasca's Avatar
Drives: yaris
Thumbs down NEED TB CHIP SWAP ADDED
It has been taken down, and I think I am not the only one wanting it.
Power-to-Weight Ratios of Yaris, Fit, Mini, etc. Idjiit Off-topic / Other Cars / Everything else Discussions 6 10-06-2017 05:10 PM
