Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 10-20-2008, 02:12 PM   #1
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Yaris TS Performance Parts Compatibility Thread
As you must know, there is almost ZERO support on performance parts specific for our cars as of today.
This situation lead us to look at other Toyota cars for parts compatible to us.
The intention of this thread is for you to post CONFIRMED compatible parts for the Yaris TS.
Old 10-20-2008, 02:16 PM   #2
CASTREX
CASTREX's Avatar
Yaris TS suspension components
Yaris suspension components.
I have installed a Tein Coilover system from a US spec Yaris into my TS with no further problem or modification involved.
I know of a couple of members also using the H&R lowering springs. These springs are also offered for the regular and the US spec Yaris, therefore we can say the other Yaris suspension components (Springs, performance shocks and coilovers) will work on our cars.
Link to the thread for the Coilover Instalation on the TS:
http://www.yarisworld.com/forums/showthread.php?t=9586
Old 10-20-2008, 02:20 PM   #3
CASTREX
CASTREX's Avatar
US TRD rear Sway Bar
US spec Yaris TRD rear Sway Bar.
I believe this one is hard to find outside the US, but I believe there are other Yaris rear sway bars.
Here is a Pic of a US spec TRD rear sway bar installed on my TS:
Old 10-20-2008, 03:52 PM   #4
CASTREX
CASTREX's Avatar
Leather shift boot
US Yaris leather shift boot from Redline goods:
http://www.redlinegoods.com/Yaris9906shiftboot.shtm
Mine is black leather with JDM red stiching to match my Razo weighted Shift Knob.
Old 10-20-2008, 04:11 PM   #5
CASTREX
CASTREX's Avatar
Fujita Cold Air Intake
I didn't wanted to go for a K&N replacement filter since there is not much gains other than not having to change the filter any more.
First I went for a "semi" Short ram intake.
To do it I removed the hole filter plastic box assembly keeping only the OE plastic housing for the MAF sensor.
The I just installed a High Flow filter directly to the MAF housing and made a small bracket to hold the intake in place. I used a HKS mushroom filter since I really like the look of those ...
Then, a few weeks ago a reputable US intake manufacturer FUJITA announced the release of their new CAI (Cold Air Intake) for the US Scion xD car. (Toyota IST in Japan).
For those who don't know, the Scion xD is based on the Yaris chassis and the US version comes equipped with the 2ZR-FE 1.8L engine.
So I took the chance and ordered one of these to try it on the Yaris TS.
The result: Is and ALMOST fit..! The only part that doesn't fit 100% is a bracket used to secure the pipe that is a little shorter than it should for our cars.
Other than that, the Scion xD CAI works perfectly on our cars. See below a picture of the cai installed on my TS.
I found that the bracket is not required so it won't prevent the correct function of the intake. The air filter is relocated right below the headlight and it sit there really snugged. So there pipe is not moving around...
I have had the intake installed for a few weeks with no problem at all.
Old 06-12-2009, 03:31 PM   #6
CASTREX
CASTREX's Avatar
Update with new parts:
1)Scion xD AFE Intake, works on the TS.
2) NST Short shift kit (SSK) Will only work on the 07/08 5 speed TS. It will NOT work on the 6speed shifter.
3) NST Cable Metal Bushings. Will work on on the 5speed TS. Not yet confirmed on the 6speed but it looks like it would work.
4) NST underdrive pulley for the Scion xD. Works like a charm on all TS with the 2ZR engine.
5) TRD Brake pads for the Scion xD. These WON't work on the Yaris TS. Although they are the same shape and height, the Xd pads are a little bit longer than the TS pads.
(I will be attempting to machine some these pads to make them fit)
Old 06-12-2009, 11:58 PM   #7
NonStopTuning
Excellent thread!
MIKE @ NST
www.NonStopTuning.com
Old 06-26-2009, 08:40 PM   #8
lammy29
will it fit with the Shifter extension?
lammy29 is offline   Reply With Quote
Old 06-26-2009, 10:22 PM   #9
CASTREX
CASTREX's Avatar
Redline boots are quite long.... I have to folded mine to make it fit alright.
So I guess it can work with about 1.5" longer stick.
You can also request a longer boot when you are orderinng from redline.
Old 11-07-2009, 05:18 PM   #10
oxide666
SR Badboy!
Drives: 1.8 sr Chilli red
Question
how did u manage to fit it behind the headlight is it a tight space did u have to take anything out
oxide666 is offline   Reply With Quote
Old 11-07-2009, 05:56 PM   #11
CASTREX
CASTREX's Avatar
It fits... a bit tight but it does. I've had it there for over a year now.
Another good option is the AFE intake for the xD. that leaves the filter on top.
Old 11-07-2009, 06:08 PM   #12
oxide666
SR Badboy!
do u mean the stage 2
not the cai?
Old 11-07-2009, 06:12 PM   #13
CASTREX
CASTREX's Avatar
not the cai?
yes that one.
They actually call it a cai as they privide some form of enclousure for it. many members with the 1.5L yaris have it and their are very happy with it.
You can get the xD afe cai from caliyaris (forum sponsor and AFE distributor) he ships worldwide fyi
Old 11-07-2009, 06:15 PM   #14
oxide666
SR Badboy!
ah wkd will have to pm him bin looking for some parts so hard to find n get to uk thanks for info
Old 11-07-2009, 06:21 PM   #15
tcpty
TSport Underdog
tcpty's Avatar
Drives: 2008 TS Storm Gray
How about a set of HEADERS for the TS? Anyone with any experience? Compatibility?
tcpty is offline   Reply With Quote
Old 11-08-2009, 02:30 AM   #16
CASTREX
CASTREX's Avatar
Nope. Nothing yet. a compnay has been working on some headers for the scion xd that should fit our car... but nothing has came out to the market yet!!
Old 11-08-2009, 02:38 AM   #17
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by NonStopTuning View Post
Excellent thread!
+1
Thread is now stuck.
Old 11-11-2009, 02:58 PM   #18
tcpty
TSport Underdog
tcpty's Avatar
Anyone know if the Cat-Back exhaust being sold for Yaris 1.3 or 1.5 can be used on a 1.8 TS?
The Yaris Performance Primer eTiMaGo Performance Modifications 30 01-24-2024 04:26 AM
The official Yaris Taillights thread Razr Cosmetic Modifications (Exterior/Interior) 40 06-12-2007 09:08 AM
