Old 05-12-2009, 08:33 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
09 Fog Light Install
I just want to make sure I'm doing this right before I finish so I don't have to tear everything apart again. I'm installing Micro Image fogs ( http://shop.microimageonline.com/pro...&productId=103 ) in an 09 LB and will be using the OEM stalk, not the supplied switch. I followed the supplied Toyota installation manual and I think I have a bit of a problem. Step #12 shows 2 wires (red/brown & red/white) connecting to pins 1 & 2 in the fuse panel but.... the wiring harness I received has 2 solid red wires. Does it matter which wires goes to which pin?
I used the headlight ground (near the air cleaner assembly) to ground the fogs and plugged in the supplied relay under the dash. Am I correct in assuming all that's left for me to do is install the OEM stalk? No more wiring necessary?
MGargano is offline   Reply With Quote
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 06:15 PM
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 02:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 07:46 PM
