![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
What could cause the difference in rear toe?
Well I went back up to the stock setup with the stock springs and shocks. After getting the alignment done, since I knew for sure the front's would be way off, the rears came back entirely within spec. But they varied a fair amount. The rear left was about .09 and the rear right was at .28. I'm not quite sure why their would be such a variance even though it's still within spec. Is that much difference in the two going to hurt anything? Has anyone elses rear toe specs came back similar before?
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
what were the previous settings vs now ?
pothole, or a large bear, could have done that |
We aren't driving machines of precise engineering.
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
I think that amount of difference could easily be factory tolerance. You shouldn't have any problems.
It wouldn't hurt to check the (rear)springs, make sure they are seated properly (they determine ride height, which will change your toe slightly). |
![]() ![]() Drives: 07 Mazda MX5 Copper Red Join Date: Jun 2009
Are you still using the upper hole for the rear suspension?
Brent Former Yaris Owner |
I lowered the arms to the lower hole, so everything's back to factory specs. According to the printout I got from the alignment place, .28 is still within tolerance. I believe it was from .03 to .31 that is tolerable. I just wonder why such a wide variance.
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
probably because they adjusted it. <not sarcasm.
Curious why you went back to stock?
I thought the rears are unadjustable?
And I went back to stock because driving on hard packed snow for a few months with relatively stiff springs and stiff shocks is not a very pleasant thing to endure lol. Perhaps in the spring I'll go back to the lowering setup. |
After I installed my TRD parts I took it for alignment. I can't recall the spec.'s but my rears were not equal but were within OEM tolerance. The Tech suggested he could shim to make them equal but felt it wasn't going to be an issue. Many thousands of kilometers later the rears are wearing equally.
my rear toe was 0.06" and 0.14" before adjustment. and 0.07 and 0.12 after.
There's always a light adjustments within the bolts.. My yaris have something in the front that is slightly out of spec.. i was told it did not affect anything.....
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
| Rear toe adjustment...shims?? | ozmdd | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 10-15-2009 10:32 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
| Difference b/w TRD Rear Sway Bar and these? | IsLNdbOi | Performance Modifications | 8 | 11-11-2008 09:13 PM |
