Old 10-15-2009, 10:32 PM   #1
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Rear toe adjustment...shims??
I need to get rid of the factory toe-in on the rear wheels. I'm currently at -1.0 deg camber on both sides, and +0.3 toe on the left and +0.07 on the right. Wanna get to zero toe-in or even a bit of toe-out, and camber can either stay-put or would be fine if it increased to no more than -1.5/side. How can this be done, and can the correct shim be calculated accurately, or is this trial-and-error?
I'm not getting any roll-over onto the shoulders even in hard cornering on concrete, so I don't feel the need for much camber tweaking.
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
New Product: Penguin Garage Rear Camber Shims! Penguin Garage Penguin Garage 11 10-22-2009 10:20 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
