that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
so every now and then when I start it up the cluster is like REALLY dim to a point where I can barely see it....anybody else have this problem? this just started few months ago. took her to the dealership and they wanted $140
up front before they'd even look at it.....and btw what's the warrenty on this thing? they treid to tell me that it was out of warrenty
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
Can you fix it by touching the dimmer knob? Move it back and forth a few times and see if it improves. Is your dimmer turned all the way to the end and locked in place?
5% Tint Rear | Micro Image LED Ignition Light Kit |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
$140 up-front? You better put your foot in their down-back for that offer!
For as long as I've known the base warranty is exactly one year after purchase date.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
![]() ![]() ![]() ![]() Drives: Copper Orange Mica Yaris Join Date: Feb 2006
What he said.
![]() My Copper Orange Mica Yaris with 9.3lb Kosei K1 TS http://www.yarisworld.com/forums/showthread.php?t=10951 http://www.yarisworld.com/forums/showthread.php?t=13882 http://www.yarisworld.com/forums/sho...180#post472180 |
see I tried fiddlin with the dimmer and no dice. and it is all the way up too......it's almost like the corners are on but they ain't just the runnin lights
#6 | |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
#7 | |
Start another Oil Thread!
check your grounds and fuses.
and tell us EVERY modification that's been done to your car. aftermarket parts are the number 1 cause of factory part failure lol
you nailed it sir.
Is the illumination of the AT shifter and AC Controls dim as well?
If they are all dim, check the GAUGE fuse. If just the speedometer is dim, check the MET fuse. |
I'll have to check that cuase it's just the speedo
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
If its not under warranty find an honest mechanic, if it is under warranty find another dealer even if it means going all the way to Toledo,whatever you do dont go back to your current dealer as he's just out to screw you..
| how can i make this happen? | ryota | Cosmetic Modifications (Exterior/Interior) | 10 | 10-01-2009 07:26 AM |
| I knew this would happen | Arkhangel | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 04-30-2009 12:05 AM |
| What would happen if i disconnected this wire??? | Syroyizhka | General Yaris / Vitz Discussion | 21 | 04-06-2009 11:06 PM |
| wat happen if u ebrake going 80mph? | Blenjar | Off-topic / Other Cars / Everything else Discussions | 29 | 06-15-2007 11:09 PM |
| i happen to have a 1.8 fuel injector | critical | Performance Modifications | 3 | 03-13-2007 12:57 AM |
