Old 04-26-2009, 06:39 PM   #1
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
I knew this would happen
Well serves me right buying the cheap lug nuts
I put then on yesterday and one already chipped...
any recommendations for replacedments? would like them in blue :D or black
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 04-26-2009, 07:27 PM   #2
hmm, I see a big black circle where the top of the lug nut should be?
Old 04-26-2009, 07:49 PM   #3
Arkhangel
Arkhangel's Avatar
oh no sorry thats just the key.. pic was just to reference the lugs i bought
Old 04-26-2009, 09:34 PM   #4
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Even the nicest ones will still wear down a bit after a few removals.
Old 04-26-2009, 11:39 PM   #5
Grandieri
Grandieri's Avatar
Drives: 2010 Matrix
Skunk2 ftw!
Grandieri is offline   Reply With Quote
Old 04-26-2009, 11:45 PM   #6
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
It depends on how you take on or take off your wheels. If you use an impact wrench, its more a chance for damage. I havnt had any problems with mine, wheels have been removed at least 4-5 times now. Only 1 time with an impact.
Old 04-27-2009, 12:02 AM   #7
Arkhangel
Arkhangel's Avatar
no impact wrench been used since i put the rims on on Saturday, thats what buggin me i bought the lugs nuts on sat took off today to paint calipers and one aready chiped
Old 04-27-2009, 12:05 AM   #8
Arkhangel
Arkhangel's Avatar
Originally Posted by Grandieri View Post
Skunk2 ftw!
yikes expensive, i guess you get what you pay for
Old 04-27-2009, 07:01 PM   #9
Grandieri
Grandieri's Avatar
Drives: 2010 Matrix
Yeah they look sick though.I just put them on mine.
Old 04-27-2009, 07:07 PM   #10
tk-421
tk-421's Avatar
Drives: 5D-07-LB
CorSport seems to have some good ones in stock:
http://www.corsportusa.com/store/cat...x.php?cPath=46
Old 04-27-2009, 08:10 PM   #11
xen555
xen555's Avatar
Drives: 3 DOORS LB
medero en caguas vende los VISION MOTORSPORT son anodize aluminum y vienen en negro rojo y azul creo que tambien salienton en gun metal y te salen 60 los 16... yo estoy a punto de comprar los rojos y son dificiles de conseguir...
xen555 is offline   Reply With Quote
Old 04-27-2009, 08:38 PM   #12
Arkhangel
Arkhangel's Avatar
Gracias tipo
Old 04-27-2009, 09:16 PM   #13
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Take those off ASAP!
I'm not joking. I had a similar set seize on the wheel/studs, and ended up needing an air-hammer to remove them, as of course, the sides were all worn out (just from torquing at 70ft/lbs!) Of course, I chewed up the rim (which were long out of existence by then) using the air impact tool. Cost me four new alloys, all because I scrimped and used cheap Ebay (similar) lug nuts.
Buy a good set, they'll pay for themselves in no time!
firemachine69 is offline   Reply With Quote
Old 04-27-2009, 10:21 PM   #14
schleppy
I love momentum.
schleppy's Avatar
Always hand tighten lug nuts (aftermarket or not). Air tools + lug nuts = lose (even if you have the correct torque stick). It only takes a couple extra minutes...
Old 04-28-2009, 12:21 PM   #15
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Seconded. I own an impact, and NEVER use it to install lug nuts, plated or not! Torque wrench only.
I learned my lesson when a tire shop stretched every wheel stud on my old car. True, the studs weren't the standard size ("normal"), but it was an unnecessary waste of time and money to replace them all.
Old 04-29-2009, 09:58 PM   #16
Arkhangel
Arkhangel's Avatar
i stop using impact gun the day i work on my Fairmont and per my Neighbor who is a mechanic put my wheels back when for a drive and felt the steering wheel stitch , when igot to my friends house i asked him what it could be he noticed one of the lugs was loose i was like never used an impact on my car again just dont trust them. now even if the tire shop uses an impact on any car im driving i still check them out with the tire iron, more then once noticed a couple of them loose...
Old 04-29-2009, 11:05 PM   #17
RomGrr
RomGrr's Avatar
Drives: 2007 Yaris HB
I won't use an impact either. In fact, every time I've gotten a flat I've taken the wheel off and taken it to the service station either in another car or put the spare on the Yaris, just to avoid the over torquing that the monkeys in the tire change shop are likely to inflict on my lugs. I'll trust them for a mount and a balance but that's about it.
RomGrr is offline   Reply With Quote
Never gonna happen in North America. IllusionX Photo-Video-Media Gallery 2 04-07-2009 11:28 PM
What would happen if i disconnected this wire??? Syroyizhka General Yaris / Vitz Discussion 21 04-06-2009 10:06 PM
5 Things You Never Knew Your Cell Phone Could Do Astroman Off-topic / Other Cars / Everything else Discussions 19 08-17-2007 09:58 PM
wat happen if u ebrake going 80mph? Blenjar Off-topic / Other Cars / Everything else Discussions 29 06-15-2007 10:09 PM
i happen to have a 1.8 fuel injector critical Performance Modifications 3 03-12-2007 11:57 PM
