Old 02-06-2010, 09:30 PM   #1
biasrutus
Drives: Yaris
Spring and Strut Combo
Today I just picked up my 08 CPO with less than 20k on the odometer. Very excited to have a new commuter with good MPG!
Question about suspension...
Does anyone sell the springs already on the struts so I don't have to mess with compressing the springs?
Did some searching so I apologize if I overlooked the obvious...
biasrutus is offline   Reply With Quote
Old 02-06-2010, 09:50 PM   #2
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
as far as I know I haven't seen that combo, but you can easily DIY with some spring mcpherson compressors and a socket wrench
RacerFreakXXX is offline   Reply With Quote
Old 02-06-2010, 10:58 PM   #3
DARK AGE 53
Drives: 2009 Yaris Onyx
Check with Garm at Micro Image, you might be able to work out a deal with him.
DARK AGE 53 is offline   Reply With Quote
Old 02-06-2010, 11:53 PM   #4
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Where are you located in texas? When are you getting springs and struts/shocks? I am having an install day at my house in March here is the thread on it: http://www.yarisworld.com/forums/showthread.php?t=25580
Old 02-07-2010, 12:32 AM   #5
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I'm thinking about switching things up and going with the Tokico HPs and Tein S-Tech combo. I don't need adjustability (never use it), but still want a sporty, good-looking combo.
Old 02-07-2010, 07:41 AM   #6
biasrutus
Drives: Yaris
Thanks for the heads up. I am in San Antonio area, but go to Dallas every once in awhile.
Old 02-07-2010, 11:53 AM   #7
lilredrocket
Slowy getting there
Drives: 08 Liftback
Hit up so of the other guys in the SA area I'm sure they would be will to help you out!!!
Old 02-10-2010, 01:57 PM   #8
eht13
Drives: .
What about lowering springs (such as Tanabe or TRD) being used in conjunction with the stock shocks? I wonder because I feel like I have seen a lot of people here get lowering springs but not mention changing their shocks at all... so I wonder if that is a bad idea in the long run, or would it be OK?
eht13 is offline   Reply With Quote
Old 02-10-2010, 04:26 PM   #9
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Running some mild drop springs with stock struts is fine I believe
Old 02-10-2010, 05:51 PM   #10
^ it's fine to just do springs. The only downside is that if you want to upgrade your shocks/struts later, you have to do all the work over again.
And that to get the maximum benefit of upgrading either springs or shocks/struts, they should be done together.
Old 02-10-2010, 08:43 PM   #11
DerFlosser
DerFlosser's Avatar
Drives: Yaris
I am currently using stock shocks with Tanabe DF210's and the ride is very comfortable.
DerFlosser is offline   Reply With Quote
Old 02-11-2010, 11:04 PM   #12
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
if you are on a budget and dont have a couple g's lying around to just throw down on your yaris then save and do the whole combo the first time. You'll save so much money and time and headaches.
Old 03-06-2010, 04:33 PM   #13
eht13
Drives: .
I asked this because I thought I saw something on YW a while ago advising against doing this. But it seems like most of the responses here said it would be fine. However, in just now Googling "lowering springs on stock shocks", I came across a lot of results that seemed to indicate that it probably wasn't a great idea, especially in the long run...
Old 03-09-2010, 12:24 PM   #14
eht13
Drives: .
^ So any thoughts on a lot of these search results? Thanks.
Old 03-09-2010, 02:04 PM   #15
MUSKOKA800
MUSKOKA800's Avatar
I looked at using new parts to create a complete TRD spring/strut combo and keep my OEM spring/strut assemblies intact but found it much, much cheaper to simply buy, or rent a strut spring compressor than to pay the high prices of Toyota for the necessary parts. If I recall correctly the upper strut bearings were close to $90.00 each from Toyota Canada and this is just one of the parts I'd have needed. I bought a top-o-line compressor on sale for $29.00.
In fact, for the price of the duplicate parts you could have the stealership do the install cheaper.
MacPherson Strut Spring Compressor RacerFreakXXX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 07-31-2009 09:11 PM
DIY spring install says replace strut screws? counterfiend Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 03-22-2009 08:23 AM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 10:26 PM
best spring and strut combo for the LB? drifto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 04-15-2007 07:40 PM
cusco coilovers installed badhabitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 02-03-2007 05:43 PM
