Old 07-27-2009, 07:35 PM   #1
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
MacPherson Strut Spring Compressor
Does anyone know if these actually are worth the money?
Mavis quoted me $330 to install springs and I was like wtf
RacerFreakXXX is offline   Reply With Quote
Old 07-27-2009, 08:12 PM   #2
1NZYaris1
1NZYaris1's Avatar
link not working
Old 07-27-2009, 08:15 PM   #3
RacerFreakXXX
JDM Fred
works now, lol
Old 07-27-2009, 08:25 PM   #4
1NZYaris1
1NZYaris1's Avatar
Ahh , so it does , and too answer your question .
i bought a similar set over here to do my spring install
they worked great , consdering how cheap they are .
i recon i could do another 3 or 4 spring instals before they are stuffed
lube the tread before you start useing them and they are even better
Old 07-27-2009, 08:28 PM   #5
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
don't buy one , most big parts store like pepboy , kragen or autozone have loaner tools that can be checked out for a deposit and all money is refunded when you return the tool .
Old 07-27-2009, 09:20 PM   #6
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
^ Thats what I did. Haha
Old 07-27-2009, 11:00 PM   #7
RacerFreakXXX
JDM Fred
see I live like 30 min away from anything like that and there is a rental place in the town over but for $50 it may be worth having in the garage just in case of an emergency.
Old 07-27-2009, 11:08 PM   #8
gte123v
Drives: 09 meteorite 3dr LB
just get these from harbor freight, http://www.harborfreight.com/cpi/cta...temnumber=3980
can't beat it for 12.99, or better yet go to the store and they are only $10. I used it to do mine.
gte123v is offline   Reply With Quote
Old 07-28-2009, 12:16 AM   #9
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
No, it's worth the 30 minute drive to go rent one. Unless you work on suspension for a living lol, no need in buying one.
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Old 07-28-2009, 02:02 AM   #10
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Was gonna say you can rent/borrow from the parts store or get the same thing from HF for about half the price (no fancy case, though). That's all been covered.
They work. Be careful. Be sure they stay 180 degrees apart as you compress the spring, scary things happen if they shift to one side. Keep them lubed, they'll work for many years.
Pro Tip: Get a socket to fit the bolt, it will really speed up the operation. Air tools are great, too... but even just a socket with a ratchet is way quicker than a big ol' adjustable wrench. (I never remember this until I've got the car apart, unfortunately!)
Old 07-28-2009, 02:04 AM   #11
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
don't use one; i didn't. :P
Old 07-28-2009, 04:30 AM   #12
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
hehe me either but I wouldn't recommend that to ANYONE!
Old 07-29-2009, 09:01 PM   #13
MUSKOKA800
MUSKOKA800's Avatar
I picked up a nice McPherson strut spring compressor at Princess Auto. Not their cheapy but the better one while on sale ($30.00, reg. $60.00). I also bought a high offset wrench (17mm?) to get squarely onto the top nuts of the front struts (as suggested in TRD installation instructions).
I figured even if I only use them once they paid for themselves in Pro labour saved and ease of use. A local parts shop does do loaners but first come-first serve and their compressor was out twice when I inquired. I had all the other required tools so buying these gave me freedom to wrench in the driveway at MY convenience.
Old 07-29-2009, 09:05 PM   #14
Loren
What?
Loren's Avatar
Nothing wrong with having tools.
Old 07-29-2009, 10:21 PM   #15
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
We don't use no tools where we're from LMAO
Old 07-29-2009, 10:24 PM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
you don't need it. put a firm foot on the spring itself while removing the top strut nut. if you need to push the newly installed spring a half inch down bring a friend. ;)
or rent a spring compressor for "free" from your local auto parts store.
Old 07-31-2009, 01:05 PM   #17
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Yup. The front springs are not under that much tension. The top hats will pop about 6 inches off the strut. not very dangerous at all if you use common sence and dont stand in front of the strut.
A friend will be able to compress the lowering spring and top hat enough so you can get on the strut shaft nut.
Old 07-31-2009, 08:11 PM   #18
RacerFreakXXX
JDM Fred
thanks for all the info... I'm pretty set on coilovers but I was wondering about spring compressors. Still probably gonna grab some just to have in the tool box.
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 05:59 PM
DIY spring install says replace strut screws? counterfiend Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 03-22-2009 07:23 AM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
best spring and strut combo for the LB? drifto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 04-15-2007 06:40 PM
