Old 10-07-2010, 07:23 PM   #1
Jason@SportsCar
rear swaybar construction?
So I can not find a definitive listing of the type of material used in the TRD and UR rear bar. Our Whiteline bar is 22mm solid, and adjustable. Does anyone know if the TRD/UR bars are solid or tubular?
Old 10-07-2010, 07:26 PM   #2
Both solid, both steel. Weight for either of the 19mm is about 13 pounds, the UR 23mm one maybe 15-16, but I could weigh one if you want something more specific.
Old 10-07-2010, 07:35 PM   #3
Jason@SportsCar
Thanks, I was just wanting to see if any of them were tubular.
Old 10-18-2010, 06:26 AM   #4
syntax
syntax's Avatar
is there any special type of solid steel for the UR 23mm rear anti-sway bar? just curious if it can be fabricated easily
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 08:20 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 05:43 PM
