![]() ![]() Drives: Toyota Yaris meteorite silver Join Date: Jan 2009
HIDs
ran into a little problem... Im not to sure where to connect this wire thats in my hand i think it goes to the battery but idk
there for the head lights H4 also the h11 has the same ones also
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
you should have a bulb adapter harness...unless you bought a cheap kit...or you can make a harness/relay setup and run power/ground to the unit. or, you can use the headlight harness adapter to power the unit but it's not as reliable.
dont mix up power ground or you could chance blowing the unit. you can use the headlight harness to power the relay and run the relay directly to the unit....is how i'd do it. |
thanks for the reply
i got it from garm so u know its good stuff
nah. you plug the factory harness in there if it fits. otherwise you'll need a harness adapter.
i think its supposed to go into a relay and connect to the battery it has a + and a - symbol on the other side
did anyone get the hid kit for the fogs from garm i check to see if it was in the DIY section but it wasnt
| auto depot headlights + HID's? | thebarber | Cosmetic Modifications (Exterior/Interior) | 42 | 01-19-2012 06:56 PM |
| installed some 3000k HID's | thebarber | Photo-Video-Media Gallery | 17 | 01-22-2010 10:45 AM |
| Where is my DRL Module......? Help With HID's | The Architect | DIY / Maintenance / Service | 6 | 05-20-2009 11:21 AM |
| DRL and HID's? | dimsum69 | Cosmetic Modifications (Exterior/Interior) | 5 | 01-12-2009 04:30 PM |
| NEW HIDS 10000k!!!!!! | elsteverino889 | Cosmetic Modifications (Exterior/Interior) | 69 | 01-26-2007 01:12 PM |
