![]() Drives: Toyota Yaris 2012 Join Date: Mar 2012
How too links!!
Does anyone have a how to link for 2012 yaris!?
And if possible for rear lights <_< |
Form>Function
What are you trying to do? Did you check the diy section?
Remove the left tail light. No I haven't , trying to remove it but it seems its stuck , by some clips holding it by the bumper or that's what I think - removed the two bolts and the side of the tail light but the bottom of the light won't budge and there's no visible screw!
If it is constructed the same as 2006-2011, then there is a pin which is pressure fitted into the body behind the light. It takes a good hard yank straight back on the light to get it out. If you shine a light into the tail light access area within the hatch, you might be able to see a pin coming through the sheet metal.
Maybe those pics of the 2012 tail light parts you had posted up will help you.
Here is a pic of the gen2 taillight. The pin is circled down in the lower outside corner.
Pin was holding it got it out . Pin broke haha -_-
Bummer. All the more reason to get those new tails. If not, a little 2-part epoxy would be strong enough to secure the broken bits together.
And guess what ... There's no bloody fkin serial codes on the tail light . So all this, a waste of time I'll take some pics and post em for every 12er out there
Part# for what? The connector? The housing? Or something else?
Connector ,housing is the same but by the pics when I take a deep look it seems like it isn't the same
Like said I want the led vitz rs but the connector doesn't seem to be the same and I'm quite sure the housing will fit anyhow , Toyota dealer next for more info digging!! And still waiting from Toyota Motorsport eu
Take a close look at the connector where the wires enter it. There may be some very, very tiny letters/numbers embossed there. I'm looking at a small connector taken from another area of my car, and that is where the part# is.
Uhm, py21w and only the likes of that codes is what I get , I've removed all the light bulbs and everything but no actual 50xxxx-xxx code
And that is written on every light bulb housing , brake light house , indicator house etc etc
Form>Function
Shame. You should get them and test em out. Then you could be the exclusive owner of these.
And sell to whom if they don't fit ? It's 330 $ a pair
#17 | |
Get some pics up so we can see what you are up against.
Form>Function
Well its not like you would have to sell them. You said that the tails would fit but the connector might not so that would mean if the connector does not fit you just have to custom wire it to fit. Doesn't mean you would have to sell it.
| Broken top plates and end links | Trish | General Yaris / Vitz Discussion | 0 | 04-07-2011 12:28 PM |
| sway bar links contd | jstantherprsn | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 03-26-2011 02:58 PM |
| aftermarket front sway bar end links? | jookybanana | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 08-08-2009 11:26 PM |
| Review: Adjustable Sway Bar End Links | m911gt | Performance Modifications | 9 | 04-29-2009 09:25 AM |
| T-Sport Tail light Sales Links | Yaris TTE JWRC | Cosmetic Modifications (Exterior/Interior) | 8 | 01-23-2007 11:07 PM |
