Old 01-10-2011, 02:18 PM   #1
jstantherprsn
Drives: 01 Toyota Echo
sway bar links contd
Hello Everyone,
I am looking at getting new sway bar links. I talked about this in the past but only got around to it now. I noticed that there are sway bar links and sway bar link kits from parts geek. I emailed them and they couldn’t tell me if there is a difference. I noticed that the febi ones are a lot different than the other offerings. Anyone know which I should go for? My plan was to get 2 sets and then go buy some poly bushings to replace them. I need new bushings in order to measure up to get the polys. I honestly can’t tell the difference they all look the same except for the febi one. Just wanted some advice some someone who has already changed their links.
jstantherprsn is offline   Reply With Quote
Old 01-16-2011, 05:52 AM   #2
birdman
my TRD bar bolted up with no links or bushings and works fine.
Old 03-25-2011, 05:54 PM   #3
jstantherprsn
I got the febi sway bar links. The link is machined from a single piece of bar stock. Other kits just provide a bolt and standoff, washers etc. So the kit is a new stud and everything else. It looks like its hot dipped. Now I'm looking at urethane bushings. When I find ones that work I'll let everyone know.
Old 03-25-2011, 08:49 PM   #4
sickpuppy1
Drives: 2010 Yaris Sedan
Why replace the links if they don't come with better bushing ie; urethane?
Old 03-25-2011, 09:26 PM   #5
severous01
because if you lower you need longer (or shorter depending on setup) end links to make up for the difference in ride height.
the end that hooks to the suspension needs to be level with the ground at rid height. so if you lower 2" you'll need 2" shorter ends. if you're sway bar is not level it will not be as tight and responsive....or more responsive in leaning one way and less in the other depending on how far you lift/drop the car.
and for those who want to argue....do what you will if it works for you
Old 03-26-2011, 03:58 PM   #6
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
My ksport coilovers have adjustable collars that the stock end links attach to. I can either bring the collar up, which results in the sway bar going up, or bring the collar down to where the sway bar is barely missing the bar under it. I'm lowered and not to sure how the sway bar should be positioned. Help!
marlondog is offline   Reply With Quote
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 06:25 AM
adjustable sway bar end links group buy!!! turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 51 06-13-2012 12:49 PM
sway bar links jstantherprsn DIY / Maintenance / Service 3 11-02-2010 01:12 PM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-09-2009 12:26 AM
Review: Adjustable Sway Bar End Links m911gt Performance Modifications 9 04-29-2009 10:25 AM
