![]() Drives: Cute-as-a-bug Join Date: Jun 2007
Rear Shocks Replacement? Water Pump.
(First Post.) I have a 2007 Yaris Liftback bought new. 88,000 miles. Never had any problems except AAA Auto Repair, (Camelback Phoenix,) told me my water pump was leaking. They say its a "Corolla/Yaris" issue(?) They tried to show me with a flash light, but I never could see the green crusting indicating a leak. They also said the whole pump needed replacement. I though you could replace a gasket or something. Now they say one rear shock is leaking and therefore they suggest replacing both rear shocks. $500. I said yes and then called and cancelled. I have never owned a vehicle that needed shocks replaced. Did I just get lucky? I figured when I am jouncing down the road, that would be time to replace the shocks, but $500 sounds expensive. No? I have never had brake work done and the mechanics always think I have new brakes. Did I get lucky?
![]() ![]() ![]() Drives: 2012 Yaris SE Join Date: Nov 2011
I'll meet you at a rest stop on the Turnpike and install my like-new rear shocks for you, while you wait and sip coffee, for considerably less. PM me.
By the time you get to Phoenix ...
... totally cool 'cept I moved to Phoenix. Just updated my profile. But, really appreciate the offer.
Toyota (TM) Shareholder
$500 for just the shocks is expensive. I would say $250-300 installed using an OEM equivalent like KYB GR-2.
The coolant is pink so you would see pink speckling. The water pump must be replace as a unit. There you also have choices that are superior to OEM and cost less money. |
I think '07 had that issue with the water pump but not sure.
the struts are pretty easy to change by yourself. I think it is just a bolt at the top and one at the bottom. (I know it is just one nut and bolt at the bottom from a sway bar install, not sure about the top). I know guys that have done struts and springs for less than the dealer is quoting you though they did the install themselves. brakes have a lot more to do with how you drive. My brother-in-law has a ranger that he finally changed the brakes on at around 150,000 miles but he drives a stick and slows down by downshifting. He hardly every hits the brakes. |
What's a good replacement for the rear shocks?
I'm looking for good performance and good economy. |
repairpal.com
We have KYB OEM replacements and Tokico blues if you want to upgrade -- all in stock, and I am willing to sell pairs (front or rear separately).
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Water Pump Pulley | Vioz | DIY / Maintenance / Service | 14 | 08-14-2011 04:29 PM |
| Water Pump gave up on me finally | Vioz | DIY / Maintenance / Service | 4 | 07-31-2011 06:08 PM |
| well water pump its almost out of commission.. | marcus | DIY / Maintenance / Service | 5 | 07-08-2011 10:03 PM |
