Old 01-28-2017, 07:08 AM   #1
rizaydog
rizaydog's Avatar
Drives: 2016 5 Door Yaris
2016 Yaris Hatchback Navigation & Apps question
I just bought a 2016 5 door hatchback yesterday. The stock stereo is a touch screen unit. One of the buttons said "Apps". When I pressed it, it said apps and navigation are not available. I asked the dealer about it. He said the Yaris comes with the same radio as the bigger vehicles but the apps and navigation you can't get with the Yaris. He also said that these option use your data through your cell phone.
Is this true? Is there any way I can get these option to work with this car? I am guessing if the stereo is the same, the access for those option must be a paid service.
Thanks for your help,
Ray
rizaydog is offline   Reply With Quote
Old 01-28-2017, 10:17 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I think there is a app for your phone you can download to interact with the stereo in the USA
Old 01-28-2017, 12:07 PM   #3
I believe you'll need the GPS module. It's a dealer installed option, or you may be able to DIY. As far as the apps, I don't think the Yaris Entune unit has any. It does not get the Entune App Suite that the other Toyotas get.
Old 01-29-2017, 07:07 AM   #4
rizaydog
rizaydog's Avatar
Thanks for the information guys.
My phone does interact with the yaris in some ways via bluetooth. I can make and receive calls as well as play music that is on my phone through the head unit. Thats about it.
Your right Kaotic, there are no apps installed on the head unit.
So, it appears the hardware is the same as other model vehicles, but the entune software you must not be able to get for the yaris.
If the gps module is installed, would it be in the head unit or some place else in the vehicle?
I asked the dealer if there was a way for me to get full function of the head unit with gps navigation and apps. He said no, you can't with the yaris. Does anyone know if I could buy this same head unit and gps module out of another model car and get it to work with these functions? It sounds to me the units are made the same until software install.
Old 01-30-2017, 05:42 AM   #5
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
There is a dealer add on for GPS that exists. Its called an extension box. I did try using one from a prius c but it didn't work unfortunately.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 01-30-2017, 02:24 PM   #6
pribek
Drives: Man
Send a message via ICQ to pribek Send a message via AIM to pribek Send a message via Yahoo to pribek
Here is the solution, but is not cheap
You may use http://car-solutions.com/en/video-ca...e-monitors.php + http://car-solutions.com/en/smartpho...mi-outputs.php
or much more expensive
http://car-solutions.com/en/navigati...ta-touch-2.php
Best regards
pribek is offline   Reply With Quote
Old 01-30-2017, 02:34 PM   #7
pribek
Drives: Man
There is a solution. See here:
or here (much more expensive)
Best regards
Old 01-30-2017, 04:05 PM   #8
You'll need the the extension box that will enable the GPS portion to work.
Part number PT296-47141 https://www.toyotapartsdeal.com/oem/...296-47141.html
Then you'll need the GPS antenna kit. Part # PT296-00141-AA
https://www.toyotapartsdeal.com/oem/...-00141-aa.html
That kit should include the antenna itself, GPS plate, cable ties, wire clips, and foam adhesive pad.
Lastly, the extension brackets. Part #'s 86211-0D140
https://www.toyotapartsdeal.com/oem/...211-0d140.html
https://www.toyotapartsdeal.com/oem/...212-0d140.html
Just install everything. I think the first link had an installation guide in it. Your local dealership is just being super lazy to look up information.
Old 01-30-2017, 04:12 PM   #9
Prius c is a different type of Entune head unit. Plus, I believe you'll need a VIN for a Prius c for it to work.
Old 01-30-2017, 04:16 PM   #10
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Close to $800 when all is said and done. And that's just in parts. Add in your time to install...Just get a good mount for your phone and use that, or a cheap Garmin.
Old 01-30-2017, 04:24 PM   #11
I'd rather spend that money on an Alpine or Pioneer headunit with a built in nav.
Old 01-31-2017, 04:58 AM   #12
rizaydog
rizaydog's Avatar
Thanks for all the replies. I will take a look at all these options.
Tags
apps, navigation, radio, stereo
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Yaris hatchback front seat question mr.white_hb Cosmetic Modifications (Exterior/Interior) 2 08-23-2009 04:04 AM
New Yaris + warranty Question hpvampiress New YARIS Purchase Forum 9 06-29-2009 06:39 PM
