Old 01-30-2017, 05:05 PM   #1
Originally Posted by rizaydog View Post
Thanks for the information guys.
My phone does interact with the yaris in some ways via bluetooth. I can make and receive calls as well as play music that is on my phone through the head unit. Thats about it.
Your right Kaotic, there are no apps installed on the head unit.
So, it appears the hardware is the same as other model vehicles, but the entune software you must not be able to get for the yaris.
If the gps module is installed, would it be in the head unit or some place else in the vehicle?
I asked the dealer if there was a way for me to get full function of the head unit with gps navigation and apps. He said no, you can't with the yaris. Does anyone know if I could buy this same head unit and gps module out of another model car and get it to work with these functions? It sounds to me the units are made the same until software install.
You'll need the the extension box that will enable the GPS portion to work.
Part number PT296-47141 https://www.toyotapartsdeal.com/oem/...296-47141.html
Then you'll need the GPS antenna kit. Part # PT296-00141-AA
https://www.toyotapartsdeal.com/oem/...-00141-aa.html
That kit should include the antenna itself, GPS plate, cable ties, wire clips, and foam adhesive pad.
Lastly, the extension brackets. Part #'s 86211-0D140
https://www.toyotapartsdeal.com/oem/...211-0d140.html
https://www.toyotapartsdeal.com/oem/...212-0d140.html
Just install everything. I think the first link had an installation guide in it. Your local dealership is just being super lazy to look up information.
Old 01-30-2017, 05:16 PM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Close to $800 when all is said and done. And that's just in parts. Add in your time to install...Just get a good mount for your phone and use that, or a cheap Garmin.
Tags
apps, navigation, radio, stereo
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-07-2012 12:37 AM
Yaris hatchback front seat question mr.white_hb Cosmetic Modifications (Exterior/Interior) 2 08-23-2009 05:04 AM
New Yaris + warranty Question hpvampiress New YARIS Purchase Forum 9 06-29-2009 07:39 PM
