![]() ![]() Drives: Yaris HB Join Date: Dec 2014
Well, last weekend I changed all the pipeline.
I deleted the 2 catalytics, and only conserve the resonator. I replaced it whit a custom 2" catback, it's direct from the headers to the muffler. Now the car has: • CAI with AEM filter. • DC Sports headers. • Custom 2" catback. • Magnaflow 14805 muffler. So... What else you recommend me? ![]() I was thinking in the Nology hot wire, but I have only read bad reviews about them. Other option is start to invest in handling performance like springs and bars.
VELMAX member. |
![]() Drives: toyota echo Join Date: Jun 2013
did you feel any difference with the custom exhaust?
and did you think about a lightweight crankpulley or 1zz throttlebody? |
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
i'd recommend installing a catalytic converter. first, so your car doesn't smell like old wet turd. second, because it's a FEDERAL offence to not have one on public streets. if some drunk slams in to you and rolls your car, the officer might notice the missing smog devices. just because you may live somewhere emissions tests are not conducted, it's still federal law to have one. a $10,000 fine and jail time may result. third, a high flow catalyst will only effect performance about 1/2 horsepower, but will create that much needed 1 psi back pressure.
this is just a friendly warning. do what you want with your car. it's yours. i'd recommend: porting intake manifold and installing 1zz throttle body; rear sway bar; lightweight wheels; lightweight clutch/flywheel; suspention |
#4 | |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
mine was smoother powerband after 2000rpm from exhaust system...and a slight push after 4500rpm...guess from intake? i was expecting much more.. your opinion? everybody has different butt-o-meter..😅😅😅 Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
dude, we all breathe the air. put the catalytic converter back on.
lightweight or underdrive crank pulley next
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
I'm with thebarber on both points.
Get yourself a lightweight pulley next. (Or an entire set if you wanna go all out) It will really frees up some torque, but will make the car a bit jerky, as the engine will be more responsive. And yes, definitly put a high-performance catalytic converter on, so it doesn't reduce performance, but still conforms to regulations.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#7 | |
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
![]() ![]() Drives: 2014 Yaris LE Join Date: May 2016
I think you should ditch the aem filter and get a Apex'i world filter and convert to a short ram.
DC header is good You should have gone with a larger diameter pipe for the exhaust. You should have felt a noticeable gain from removing the cats. The stock exhaust is really restrictive. Suspension and brake upgrades are always a good choice. |
#10 | |||||||
All comments talk about pulleys, I think that will be the next step. Quote:
The 1ZZ TB is one of the most popular upgrades that generates good results. Just yesterday I bought the TRD Sway Bar and the Tanabe Tower Strut Bar. Quote:
I think that the crank pulley NST calls me. Quote:
VELMAX member. |
2010EGGHATCH
Drives: White 2010 Yaris Hatch Join Date: Apr 2016
I had a 2&1/2" custom stainless catback made from the second back straight to the muffler deleted the resonator and it came out pretty decent. I also have installed the Whiteline rear swaybar, tein coilovers, UR rear upper brace, and megan racing c pillar bar (useless I know It's just for looks lol)
I'm definitely impressed with how my car performs and I'm excited to throw on the 1zz throttle body I've had sitting in my closet for a year and a half lol ![]() https://vimeo.com/199680794 Sent from my SM-G920T using Tapatalk
IG: 2010EGGHATCH |
#12 | |
The sound improved a lot and I did not lose the power I had gained.
VELMAX member. |
#13 | |
2010EGGHATCH
IG: 2010EGGHATCH |
#14 | |
Sent from my SM-N920C using Tapatalk
#15 | ||
A friend recommended a vibrant, and I was about to install a Magnaflow Glasspack. Quote:
Tanks man! I'm loving the process.
VELMAX member. |
#16 | |
2010EGGHATCH
IG: 2010EGGHATCH |
#17 |
this engine is not producing enough pressure to require anything larger than 2" diameter exhaust. i had a civic (130hp) with a 2.25 and shrunk it down to 2" and had noticeable gains.
#18 | |||
Some place to buy it online? Quote:
VELMAX member. |
| Axelback or catback ?! | TrYaris | Performance Modifications | 49 | 11-16-2012 04:05 PM |
| 2" hitch ? would any one be interested in a 2" hitch reciver? | Firefly | General Yaris / Vitz Discussion | 4 | 05-14-2012 11:30 AM |
| Custom Catback System | Sabretooth | Performance Modifications | 48 | 07-10-2007 10:59 AM |
| Catback Exhaust by Greddy! | elsteverino889 | Performance Modifications | 8 | 03-11-2007 12:05 AM |
| Catback exhaust? | elsteverino889 | Performance Modifications | 5 | 03-09-2007 11:55 AM |
