Old 09-09-2016, 05:04 AM   #7
rabbito
rabbito's Avatar
Originally Posted by invader166 View Post
I'm with thebarber on both points.
Get yourself a lightweight pulley next. (Or an entire set if you wanna go all out) It will really frees up some torque, but will make the car a bit jerky, as the engine will be more responsive.
And yes, definitly put a high-performance catalytic converter on, so it doesn't reduce performance, but still conforms to regulations.
just like invader166 stated...i went with lightweight pulley right after all your mods....you will gain slight tq and faster rpm reach 😎
Cosmetic: Toyota red emblem
Axelback or catback ?! TrYaris Performance Modifications 49 11-16-2012 03:05 PM
2" hitch ? would any one be interested in a 2" hitch reciver? Firefly General Yaris / Vitz Discussion 4 05-14-2012 10:30 AM
Custom Catback System Sabretooth Performance Modifications 48 07-10-2007 09:59 AM
Catback Exhaust by Greddy! elsteverino889 Performance Modifications 8 03-10-2007 11:05 PM
Catback exhaust? elsteverino889 Performance Modifications 5 03-09-2007 10:55 AM
