Old 04-04-2018, 06:43 PM   #1
Brettguy
Drives: 5 spd MT,black ASA iwheels
Question driveline noise after clutc/flywheel install
so my latest symptom has been a loud humming under load at 3-4k rpm, its very obvious/annoying on the highway, related symptoms is vibration of the clutch pedal at all times. what does anyone think this could be? a transmission specialist down the road sounded confident that the motor mounts were placed back incorrectly, and ive also read online about the possibility of input/ output shaft misaligment. my initial issue of a chirping clutch fork was solved with lithium grease but i feel like the throwout bearing is vibrating more than it should to begin with (after the replacement), any ideas? f*** this is so heartbreaking i love my car , if anyone experienced could chime in it'd be much appreciated!
Brettguy is offline   Reply With Quote
Old 04-04-2018, 08:06 PM   #2
tmontague
tmontague's Avatar
It's going to be really hard to say without either as much info as possible and/or disassembling the trans from the engine.
If the clutch pressure plate wasn't perfectly centered on install it could cause the symptoms you're experiencing.
The engine/trans mounts would be the cheapest and easiest to check so start with that
Tags
clutch, flywheel, noise
Strange noise after new exhaust install phaznet DIY / Maintenance / Service 3 05-03-2015 03:04 PM
metallic noise when accelerating poida DIY / Maintenance / Service 3 03-29-2015 01:20 AM
Irritating Door Noise Anakha56 Third Gen Yaris General Discussion 1 04-22-2013 12:06 AM
humming noise greg86m DIY / Maintenance / Service 6 04-14-2012 11:15 PM
Strange noise coming from left door of car daibatzu General Yaris / Vitz Discussion 3 11-19-2010 10:58 AM
