Old 06-29-2013, 09:10 PM   #1
phaznet
phaznet's Avatar
Drives: '07 Yaris Sdn
Strange noise after new exhaust install
Ever since I've had my exhaust redone I've been hearing this noise from under the car. It only happens at 600 rpm or under.
https://skydrive.live.com/redir?resi...EMrIpiWAa3eQzE
phaznet is offline   Reply With Quote
Old 06-30-2013, 10:24 AM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Video wont play for me. But usually something at that low of an rpm is usually vibration...body contact
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-30-2013, 11:08 AM   #3
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Video loaded for me and that is exactly what it sounded like. Almost the same sound as when you have a heat shield come loose and it vibrates against the exhaust.
OP, when the car is off and cooled down, go underneath and wiggle the exhaust a bit and see if you can figure out what is rubbing and where.
Old 05-03-2015, 02:04 PM   #4
phaznet
phaznet's Avatar
I know this is an old thread, but I finally figured out what the noise was: A bad flange gasket (from exhaust manifold to cat. converter).
Looks like they didn't replace it when I took my car in to get a new exhaust.
Strange noise Black_griffin6 DIY / Maintenance / Service 10 04-14-2014 08:01 AM
Another Tanabe Medallion Exhaust Install CharlieBravo Performance Modifications 20 02-18-2013 12:54 PM
My car is making a strange noise, and it's only 4 months old... Ktszeligo General Yaris / Vitz Discussion 4 12-26-2010 06:13 PM
Strange noise coming from left door of car daibatzu General Yaris / Vitz Discussion 3 11-19-2010 09:58 AM
anyone use Dynamat/ Be Quiet to deaden exhaust noise? Galavoxx Performance Modifications 9 11-29-2006 04:28 AM
