Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
While doing a build for a YW member, we learned a lot about how the older and newer transmissions differ. You can read the whole article HERE:
http://www.armstrongfamilyblog.com/a...0-transmission
![]() Drives: Toyota Echo Join Date: Oct 2016
Great stuff, you did all the hard work for me/us I was planning on looking/comparing the differences too, Australia is littered with these C15(x) gearboxes.
Now I gotta find a C56 and do the same 6 speed as you did.
Data doesn't lie
You can use your current bell housing for any future upgrades. You only need to change the output shaft bearing from the 33mm to the 40mm. Then use the rest of the C56 or C60 parts(and axles unless you use a Yaris C50 diff).
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
so in theory...I can take a tercel 150 bell and bolt it to a 4.31 scion c5x trans?
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
How much to build me an lsd trans for my 07 Liftback? I prefer to keep it the stock 5 speed
| C160 Helical LSD in a C50 transmission? | ZAKU | Performance Modifications | 9 | 04-13-2024 02:07 AM |
| C150 and C50 series ring gear question | Ronnie V | Performance Modifications | 16 | 03-18-2019 07:14 PM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 03:52 PM |
| C150 Vs C54 | Parmas | Performance Modifications | 14 | 05-14-2010 07:14 PM |
