Old 04-28-2010, 09:59 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
C150 Vs C54
I am thinking of replacing my C160 6spd transmission so I am thinking of using my stock gearbox which is a C150 or else the C54.
From research I think that the C150 is owned on yaris models between 2000-2005 while C54 is on 2006-2009 models.
The only drawback is that I will loose the much needed LSD of the C160 so I asked if the C160 LSD can be used on the C150 to "Bluevitz-rs" and he said that the diff do not match the c150 since it is 6bolt instead of 8. Although he said that a C54 diff match the C160.
I am really confused what to decide since the gear ratios of the C150 are better than the C54.
- If I choose to stay C150 I get better gears and I need to buy an LSD (which is expensive) for it
- If I choose to use C54 I get a slight loss of gears ratio but then I can use the C160 LSD
Also I do not know if the C54 and C150 dimensions are the same since I don't want any issues putting it or else not matching drive shafts.
Please help
C150 vs C54 Compared -> http://www.fatboyraceworks.com/gears...raph&Compare=1
Not sure if the C54 final drive is 3.545 please confirm
C54 MANUAL TRANSAXLE service manual needed ricepower DIY / Maintenance / Service 1 08-29-2007 07:24 AM
