Old 08-22-2007, 06:30 PM   #1
wushumasterku
Drives: 06 White LE HB 5spd
tire size
so i've decided to go with df210 and 15 inch wheels
for my tires, should i go with 195/55/15?
or maybe a 205? can you share some experience on this?
thanks
wushumasterku is offline   Reply With Quote
Old 08-22-2007, 06:40 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
I think 205/50's would work really well for you.
Old 08-22-2007, 09:42 PM   #3
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
+1
reznunt is offline   Reply With Quote
Old 08-23-2007, 02:36 AM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
here, the YW wheel and tire guide
http://www.yarisworld.com/forums/showthread.php?t=5021
Old 08-23-2007, 10:16 PM   #5
wushumasterku
thanks
i looked at that chart
205 50 16 611.40 24.071
or
205 50 15 586.00 23.071
is better with DF210???
Old 08-23-2007, 11:44 PM   #6
kimona
kimona's Avatar
Originally Posted by wushumasterku View Post
thanks
or
With DF210's, you can run 15's or 16's. It's your choice.
With 15's and 205/50's, you don't need to worry too much about the wheel offset because of the short tires.
However, if you want to run 16x7's with 205/50/16's, then wheel offset is critical. To avoid rubbing problems, don't run less than ET42mm. If you choose to install wheels with ET38-40mm, then you should go with 195/50's or 205/45's.
Old 08-23-2007, 11:50 PM   #7
Black Yaris
der Zeck
205/50R16 would be better because personally I would not want the other size because it is much smaller of a size, and that is not my cup of tea
Old 08-24-2007, 12:17 AM   #8
kimona
kimona's Avatar
This is the Toyota Vitz OEM wheel and tire size: 16x6, ET51, 195/50/16
Most (lowered) Vitz 16" tire upgrades are to 205/45/16.
195/50/16 is a very common tire size in Asia, but not here in the States. We've been installing 205/50/16's because they are readily available and really cheap.
But, 205/50/16's won't work with DF210's and 16x7, ET38's, for example; you'll have to go with either OEM 195/50/16 or with 205/45/16's. These tires are not too short.
Old 08-24-2007, 12:26 AM   #9
Black Yaris
der Zeck
why tell him to run a +38 then? 205/50R16 would be perfect with a +42..... I am not saying they are too short... I am saying they are too short for my taste.... when you put a smaller tire on like that you just open the wheel gap back up, and that completely defeats the purpose of lowering your car in the first place....
Old 08-24-2007, 12:35 AM   #10
kimona
kimona's Avatar
Yeah, I completely agree with you about wheel gap, but if you look at CaliYaris' car, he is running 16x7's, ET38, 195/50/16's... and they look really tight. He initially installed 205/50's but encountered rubbing problems.
So, I'm not telling this guy to run ET38's, but you know yourself, BlackYaris, some guys just want a particular wheel regardless if it's the best offset for the application or not. So, if he chooses to run ET38-40mm, then he needs to think twice before installing 205/50's.
Personally, I like 205/50's as well, so I would choose a wheel with the proper offset for that tire.
Old 08-24-2007, 12:37 AM   #11
Black Yaris
der Zeck
True.....
+38-40 = 195/50
+42-45 = 205/50
problems solved :)
Tire size blueskana Tracking, Racing, Auto-X Forum 0 08-12-2007 10:04 PM
What to do when everyone checks your tire size... spkrman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 04-17-2007 02:03 PM
Tire Size Sabretooth Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 04-09-2007 01:28 PM
Tire size? JDMVitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-21-2007 12:03 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
