Old 08-12-2007, 09:04 PM   #1
blueskana
blueskana's Avatar
Drives: 2007 Yaris LB
Tire size
Anyone running/has run a down-sized tire and wheel set for autoX? I'm running 205/55 710 15's now, but ran across some Lenso 13x7.5's at 8lbs a piece that could go with the 710 215/50 13's. Overall diameter change is negative 2.42 in. I'd like if at all possible to be able to stay out of 1st and run higher RPM's (avg.) in 2nd/3rd gear, so I thought this might do the trick.
Thanks.
blueskana is offline   Reply With Quote
What to do when everyone checks your tire size... spkrman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 04-17-2007 01:03 PM
Tire Size Sabretooth Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 04-09-2007 12:28 PM
Tire size? JDMVitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-21-2007 11:03 AM
Need help with wheel & tire size rwseattle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-12-2006 01:10 PM
