Beast
Spring Question
I am looking for an aftermarket spring with the least drop, I don't want to put stock springs back... No control with stock springs ;d, I am thinking of putting NF210s? ARe there any that have less drop? Thanks.
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
Eibatch is only 1" drop.
Learning & Upgrading
Drives: 2006 Yaris 5 Dr HB Black Join Date: Apr 2010
U can do some research about TRD, 1.2' drop, gd enough for me. Mine run on stock shocks, still comfy enough.
always toyin'
- Procrastinators of the world unite! ...tomorrow. ![]() My Garage.. 'Mild' Drop & Misc..2-DIN GPS/Navi..DIY:Rear Wiper Delay..Ramps/Roll-Ups..Rain Sensing Wipers / Auto-Headlamps |
NF210's are 1.1/1.2, that is less than the TRD springs, which are closer to a 1.5" drop.
The NF210's are less stiff, only 10% over stock (just to compensate for the shortened spring length)
![]() ![]() ![]() Drives: yaris Join Date: Sep 2009
^^ what he says...
http://www.tanabe-usa.com/nf210.asp?id=2 If you want something higher than that.. the why not just stay stock? |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
dude, where have you been. PM me.
![]() ![]() Drives: 07 BB yaris / 06 Mustang Gt Join Date: Apr 2007
how much is it nf210 ? where can I get them .
Drives: yw calls me douche and racist. Join Date: Aug 2007
You all should see the under of my car. Its so low, the frame is kinda bashed in. I have a Carbing front control arm bar that was hella bent after hitting a pot hole.
The bottom side of my car looks like that.
Megan Racing are just 1.5 and cheaper than the others. Check them on ebay...
i had eibach prokits on the car last winter....loved them, but not low enough for my taste...
with 205-55-15 ![]() on winter 185-60-14's ![]() ![]()
#12 | |
http://www.shop.microimageonline.com...ris-TNF210.htm
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Don't mean to go slightly off-topic, but if you're looking for the best control without a big drop, you could just save a big buck and run stock springs with a rear sway bar. It's all it really needs.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#14 |
#15 |
Ultra Racing, 19mm same as TRD but less expensive, .or
23mm only from Ultra Racing Both in stock!
#16 |
#17 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Easiest performance mod you could do to your Yaris. The 23mm is a bit thicker so it's going to tighten up things a bit more as far as handling goes (keeping the body roll flat). I'd say with the 23mm that while possible to do, have a friend on hand to help fit it on one side while you get the other. Mine anyways, was a very close fit for where you install it, so it helps to have another hand to line it up.
It's not hard to put on at all though. 4 bolts and your done! The difference it makes is quite surprising, especially the 23mm.
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
#18 | |
thanx , will be buying 23mm soon :)
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
| Question about Spring rate | window_lee | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-20-2009 04:22 PM |
| Spring question? | jekqmb | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 08-19-2009 06:54 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
| spring rates question | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 05-11-2009 12:33 PM |
