Old 07-24-2010, 09:28 AM   #18
detroiter
detroiter's Avatar
Easiest performance mod you could do to your Yaris. The 23mm is a bit thicker so it's going to tighten up things a bit more as far as handling goes (keeping the body roll flat). I'd say with the 23mm that while possible to do, have a friend on hand to help fit it on one side while you get the other. Mine anyways, was a very close fit for where you install it, so it helps to have another hand to line it up.
It's not hard to put on at all though. 4 bolts and your done! The difference it makes is quite surprising, especially the 23mm.
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Question about Spring rate window_lee Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-20-2009 04:22 PM
Spring question? jekqmb Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-19-2009 06:54 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
spring rates question botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-11-2009 12:33 PM
