Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Do we have brake override?
The Yaris has not been recalled but do we have brake override?
![]() http://www.youtube.com/watch?v=VZZNR...ayer_embedded# |
Half a Bubble Off Plumb
Nope. And it'd kill the awesome dragstrip prowess of an automatic Yaris if you couldn't stand on the brakes, hit the gas and slip your foot off the brake as the light goes green.
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
Geez, people. If the throttle sticks, put the car in neutral, shut off the ignition and stop. It's that simple.
No "brake override" necessary. Just use your head. |
#4 | |
but yeah, i agree with you
What?
I've yet to see a car that doesn't allow you to shift to neutral or push in the clutch. Or one (smart key or not) that doesn't have a means for the driver to turn off the engine. This "brake override" BS is just someone trying to cash in on the hype.
![]() ![]() ![]() Drives: Loaded 2007 mica silver sedan Join Date: Sep 2007
Who needs a brake override when you have an attorney on retainer.
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
In the automatic. The shift selector tells the ECU to change to neutral. Get the ECU confused enough and maybe it will not shift into neutral. Manuals no contest. Move to neutral it is in neutral.
#8 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
Or maybe... just maybe... none of these things are very likely? Maybe people are simply irrationally distrustful of software. And maybe... just maybe... the historically dismal quality of consumer grade software like... well... Microsoft Windows... has done a lot to fuel that irrational distrust. But the embedded software world is a completely different ball game. Particularly when that embedded software is controlling critical systems. People view the ECU as though it's running the same slap-dash software as their ever-problematic laptops. And it just ain't so. -Steve |
Drives: 07 sedan Join Date: Mar 2010
^^ lol well said
The yaris doesn't have brake override, but like most vehicles, has a lot more brake horsepower than wheel horsepower.(slam on the gas and brake to see) |
#10 | |
What?
Interesting side notes: You can uplug the electronic shift cable from the transmission and drive the car shifting manually using the shift lever. (this is listed as a test procedure to verify that a shift-related fault is electronic and not within the transmission itself) The lock-up torque convertor only locks in 4th gear above 37 mph. (this is why people who accidentally drive around with the stick in 3 get such poor MPG) It's amazing what you can learn by reading the manual. |
#11 | ||
![]() Drives: 2006 Sentra SpecV Join Date: Mar 2010
Correct situation is to put the vehicle in neutral, let the engine redline, and come to a controlled stop. If for what ever reason you lose power brakes, you still have the emergency brake. You just have to make sure you don't lock up the rear wheels.
![]() Quote:
#12 | |
Being *surprised* by a lack of power assist could be a problem. Especially if you have other stuff on your mind. e.g. if you are coasting in neutral with the engine off and something completely unexpected happens, which requires immediate action. -Steve |
It's probably worth highlighting some points which differentiate the ECU's software from the buggy crap that people are used to dealing with:
1. Embedded software is more like server software than it is like desktop software. It has a very well defined set of inputs and outputs. And the software itself is not very complex at all. The number of lines of code is likely quite small. It's absolutely nothing like the average email client, or browser, or spreadsheet. All of which are vastly, unimaginably, more complex pieces of software, which must deal with vastly more varied, unpredictable, broken, and even hostile input. Particularly in the case of email clients and browsers. e.g. the vast majority of web pages on the Internet use sloppy, invalid, broken, HTML and ECMASscript. You can validate the simple main page of YarisWorld.com: http://www.yarisworld.com right now if you like: http://tinyurl.com/y9atgsu See what I mean? Your browser has to guess what the author meant by that train wreck of broken HTML and do its best to display it right. It has no check engine light to turn on. 2. The ECU software engineers have it even better than Apple's. The PC world is a hardware free-for-all. But Apple engineers have the tremendous advantage of controlling the base hardware. They don't have to worry about what SATA controller Dell decides to use on a low-line laptop. But they do have to worry about what third party video cards, etc. the user might install. The Toyota engineers control the hardware in a very profound way. Even more so than Apple. 3. All this makes testing much easier and more straightforward. The variable's are so greatly reduced. And test they do. Because if the software fails... you don't just lose all that work you put into your nifty-difty spreadsheet that you were so busy working on that you forgot to save. These companies know that they'll get a very bloody nose if they make a mistake. There is a huge incentive to test thoroughly, no doubt with lots of paperwork shuffling back and forth, to and from Toyota Legal. That's another typical hallmark of embedded software. Unfortunately, it seems that they are also vulnerable to getting a very bloody nose even if they *don't* make a mistake. -Steve Last edited by sbergman27; 03-25-2010 at 09:43 PM. |
#14 |
What?
Geez again.
Everybody... go find yourself a deserted back road somewhere where you have plenty of space and nobody around. Accelerate to 45 mph, turn OFF the ignition and try to stop your car. Now, do the same thing again, only press the brakes lightly several times before actually trying to stop the car. This will deplete much (maybe all) of the brake booster vacuum. You'll know when you run out of vacuum, the pedal will get harder. Then stop the car. It will take a bit more pedal effort than you're used to, but you CAN still stop the car. Do the same thing from 60 if you need to, just to give you more time to bleed all the vacuum from the brakes. Feel what it feels like. Know what to do. Someday you might find yourself in a situation where your engine has quit, or some mysterious vacuum leak has occurred, or some part of your brake booster has failed... it's GOOD to know what this feels like, and it's good to know that you don't need to PANIC and assume that the car doesn't have enough brakes to stop. It does. Aaaaaand, just to be sure I'm not leading anyone astray, I just went out and TRIED IT. 45-60 mph, cut the ignition, press the brakes a few times (it takes 6-8 presses just hard enough to get the brakes to engage to deplete the vacuum), and then stopped the car with no power assist. Does it take a lot more pedal effort? Yep. Is it impossible? Far from it. Again, TRY IT. This is one of those things that could save your life someday. The more you know, the less likely you are to panic when something goes wrong. Oh, and if I was recovering from a stuck throttle, I wouldn't waste those 6-8 presses of the brake pedal... I'd simply find a place to pull over and brake ONCE to stop... and I'd have full assist to do it. (you might want to try that, too... just to prove it to yourself) |
#15 |
This is what the media did to Audi in the 90s. Basically drove Audi from the US market.
None of it true. (car shifts itself into drive and accelerates) |
#16 |
Want to hear something *really* amusing? My Chevy Sprint, curb weight 1680lbs... and that's 33% lighter than the Yaris, and a featherweight car by any standards... has power brakes. (My brother chides me by calling it my "turbocharged go cart". Though I steadfastly remind him that it's not turbocharged.)
What in the world did all those drivers of pre-1930 5,000lb Cadillacs ever do without power brakes? Careen around and crash into each other, I guess. I've been in positions, over the years, where stopping my 5200lb '68 Fleetwood, without vacuum, was called for. It's definitely more difficult. But doable. Not a job I'd put my grandmother on. Especially since she's dead. Interesting point about manual shifting. I drove a 1992 Geo Metro for a while where the automatic shifting was (very) unreliable. Not knowing what it was going to do was more annoying than just doing it myself. So I disconnected its shift solenoid connectors, and treated it like a semi-automatic. Manual shifting... but with no clutch to mess with. -Steve |
#17 |
i really wish people weren't so stupid.
i mean.. com'on! those vanhool busses are DBW, does not require a key (push start) AND have electronic shifters... i have yet to see one that are faulty enough to have such problems... |
#18 |
I wish more people sat and thought about things. Bandied ideas around in their minds. Did thought experiments to examine how reasonable this or that assertion was in light of other things they know.
I wish that we did not live in such a "tabloid" world. It's not about stupidity... which is a label. It's about a willingness to employ critical thinking.... which is a behavior. No offense intended to you, IllusionX. But I wanted to make that distinction. -Steve Last edited by sbergman27; 03-25-2010 at 10:34 PM. |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| DIY For radios that require attaching a wire to parking brake | Slick | DIY / Maintenance / Service | 0 | 04-16-2009 08:14 PM |
