Old 03-25-2010, 09:06 PM   #6
QR25DE_SpecV
QR25DE_SpecV's Avatar
Drives: 2006 Sentra SpecV
Originally Posted by Loren View Post
Geez, people. If the throttle sticks, put the car in neutral, shut off the ignition and stop. It's that simple.
No "brake override" necessary. Just use your head.
Absolutely not. Never turn the ignition off and try to come to a stop. Without the engine running you're no longer producing vacuum, which your brake assist runs off of. No vacuum = no power brakes equating to pretty much zero stopping power.
Correct situation is to put the vehicle in neutral, let the engine redline, and come to a controlled stop.
If for what ever reason you lose power brakes, you still have the emergency brake. You just have to make sure you don't lock up the rear wheels.
It's not what you drive, but what drives you
QR25DE_SpecV is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
