Old 11-08-2011, 01:04 PM   #1
Jason@SportsCar
tire fitment
Its going to start sooner or later, so I thought I would share what we found...
The 2012's rear fenders seem to be just a bit tighter than the previous gen. This car is fitted with a 15x7 +35mm offset wheel, wrapped in a 205-50-15, drop is 2.5". The rear tires rub - the car valet at SEMA applied so much tire dressing you cant see the marks in the sidewalls that were made moving the car out of my driveway, but it does rub.
If the rear fenders were rolled they should easily clear the tires, or run a +38 or bigger (numerically) offset wheel.
With -camber in the front there are no interference issues.
Old 11-08-2011, 01:13 PM   #2
Do you happen to recall if stock offset is still +42 to +45?
Old 11-08-2011, 01:28 PM   #3
Jason@SportsCar
I believe that is the case. Ours came on 15x5 steel wheels, I think the offset was +45.
Old 11-08-2011, 02:24 PM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
whoa.. 15x5.. thats a skinny rim..
-Derrick-
Old 11-08-2011, 02:33 PM   #5
Standard for steelies...
Old 11-09-2011, 01:38 PM   #6
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
its actually 15x5.5
Old 11-09-2011, 01:48 PM   #7
Jason@SportsCar
Originally Posted by ROCKLAND TOYOTA View Post
its actually 15x5.5
No, it is actually a 5". I dismounted one to pull the TPS, and it is a 5" wide wheel.
Old 11-10-2011, 02:12 PM   #8
03Z33
03Z33's Avatar
Drives: TCR10
That's one of the first things I noticed about the new Yaris is that the rear now has a lip like most cars. I wish they could have kept it like the 06-11 cars without a lip, would make fitting wider wheels/tires much easier. Now we just have to see how easy it is to roll the fender without cracking the paint... shouldn't be too bad from what I could see.
Old 11-10-2011, 02:28 PM   #9
Jason@SportsCar
We will be rolling ours... But with the wrap on it we wont know for sure how the paint holds up.
Old 11-22-2011, 03:35 PM   #10
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
So I'm guessing a 205/40r17 on a 17x7 -40 will fit just fine. Perfect!
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
snow tire fitment? Phaeton Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-05-2008 06:20 PM
Tire Fitment question Ryu Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 01-14-2007 01:47 AM
