tire fitment
Its going to start sooner or later, so I thought I would share what we found...
The 2012's rear fenders seem to be just a bit tighter than the previous gen. This car is fitted with a 15x7 +35mm offset wheel, wrapped in a 205-50-15, drop is 2.5". The rear tires rub - the car valet at SEMA applied so much tire dressing you cant see the marks in the sidewalls that were made moving the car out of my driveway, but it does rub. If the rear fenders were rolled they should easily clear the tires, or run a +38 or bigger (numerically) offset wheel. With -camber in the front there are no interference issues.
Do you happen to recall if stock offset is still +42 to +45?
I believe that is the case. Ours came on 15x5 steel wheels, I think the offset was +45.
whoa.. 15x5.. thats a skinny rim..
TRIM HUNTER
its actually 15x5.5
No, it is actually a 5". I dismounted one to pull the TPS, and it is a 5" wide wheel.
That's one of the first things I noticed about the new Yaris is that the rear now has a lip like most cars. I wish they could have kept it like the 06-11 cars without a lip, would make fitting wider wheels/tires much easier. Now we just have to see how easy it is to roll the fender without cracking the paint... shouldn't be too bad from what I could see.
#9 | |
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
So I'm guessing a 205/40r17 on a 17x7 -40 will fit just fine. Perfect!
| NITROGEN GAS TIRE FILL: WORTH IT? | EjDaPogi | Middle East | 15 | 03-20-2011 02:06 AM |
| Tire rotation: Does TPMS recognize tire position? | jcdrotos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-17-2011 02:00 PM |
| snow tire fitment? | Phaeton | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 12-05-2008 06:20 PM |
| Tire Fitment question | Ryu | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 01-14-2007 01:47 AM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
