Old 12-18-2014, 01:29 PM   #1
finnpoulsen
Drives: yaris 2sz-fe
Engine warning light..please help
The engine yellow/orange warning light in the dashboard on my 2005 1.3 2sz-fe went on today :-(
The car felt normal so I continued driving home. I tried to fasten the gas cap and I also disconnected the negative terminal on the battery to see if the warning light did a reset. It didn't :-(...I noticed that the radiator fan started when I turned the ignition to on (without starting), so i let the engine cool off and gave it another try.The same thing happened, the radiator fan began spinning. It turned off and on with an interval go about a minute, even though the engine was cold. I have a had a minor leak around the water pump for some time, but has not been a problem and I always kept the coolant reservoir full...
Any ideas?
Thanks
finnpoulsen is offline   Reply With Quote
Old 12-19-2014, 09:39 AM   #2
tmontague
tmontague's Avatar
first, find out what the code is. Second, get your WP fixed. The code may be something as simple as a sensor gone bad
Old 12-20-2014, 02:22 PM   #3
finnpoulsen
Thanks..let's hope it's a broken sensor
Sent from my iPad using Tapatalk HD
Old 12-20-2014, 10:54 PM   #4
colj00
DIYer
Drives: yaris 1.5 MT
i believe that your coolant temp sensor has gone bad, its designed in a way that the fan would be on 100% of the time if the sensor failed, instead of 0%.
colj00 is offline   Reply With Quote
Old 12-21-2014, 07:16 PM   #5
finnpoulsen
Thanks...do you know where the coolant temp sensor is located?
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 03:47 PM
engine light on Foxy DIY / Maintenance / Service 3 08-24-2014 04:31 PM
2SZ-FE custom air intake check engine light JDM::RSTLESS DIY / Maintenance / Service 8 08-17-2014 12:42 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 02:43 PM
