Old 01-13-2015, 09:10 AM   #1
sully
Sully
sully's Avatar
Drives: 2008 Yaris RS
Lower control arm bolt replacement
Hi
Does anyone have a experience on how to get the vertical bolt out of the lower control arm (driver side) that has the head snapped off. It's on a 2007 Yaris hatchback. Something tells me it's going to be a pain! Any short cuts/advice would be greatly appreciated.
2008 Yaris RS
18" Kazera rims
215 35 ZR 18 Yokohama Parada tires
Borla Cat-Back Exhaust
TRD Cold Air Intake
H&R lowering springs
sully is offline   Reply With Quote
Old 01-13-2015, 11:28 AM   #2
tmontague
tmontague's Avatar
use the search function at there is a whole thread on this topic.
However to answer your Q the easiest way it seems to remove a snapped head is to weld a nut onto the bolt and then unscrew from the nut. If there is not enough of the bolt showing to weld the nut then you can try a large easy out. The other way is to remove the sub frame which would be more work.
If you don't have a welder than drive carefully to a shop and get them to weld a bolt on and remove it, shouldn't cost much.
Old 01-13-2015, 11:54 AM   #3
sully
Sully
sully's Avatar
Just finished reading the thread. Hopefully can get the nut welded on , but not holding my breath on that one...lol. Of course it had to happen on one of coldest days of the year!!
2008 Yaris RS
18" Kazera rims
TRD Cold Air Intake
Old 01-13-2015, 12:23 PM   #4
In the long thread about the potential issue with them I show some pictures of how I dealt with welding to one. The problem is that you have to drop the whole sub frame (the black plate) to get to the snapped off bolt.
Toyota did issue the warranty extension for this, so if you are under 100k, you might want to let them fix it.
Old 01-13-2015, 11:20 PM   #5
sully
Sully
sully's Avatar
Its for my other yaris 07 with 124km on it...so guessing not covered :(...All for a $9 bolt!
2008 Yaris RS
18" Kazera rims
TRD Cold Air Intake
Old 01-14-2015, 11:02 AM   #6
nookandcrannycar
I thought the bolt = covered for 100,000 miles...160,934.4 kilometers...but I guess not if the head snaps off.
Old 01-15-2015, 09:49 AM   #7
tmontague
tmontague's Avatar
I'm sure from now on you'll be checking it every 1-2 years and greasing it up ;)
I replaced mine last spring and covered the new bolts on grease. I'll be checking them this spring to see how they look. If they're fine then I'll go to every 2 years to check them.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
