Old 02-21-2015, 01:51 PM   #1
dieselphreak
Drives: 2009 yaris
09 Yaris No Start
Thanks in advance for any help. This is my mothers car, and became my problem after my step dad replaced the fuel pump in hopes of a cure. Lets start with the background. 2009 yaris, automatic, 170k. It died while driving, wouldn't start back up. Cranks just fine. I scanned it for codes with none found. I found that the fuel pump had voltage and would run during crank, but not for the initial key on. I can spray starting fluid down the intake and it will start but dies as soon as i stop spraying, with the fuel pump running the entire time, so it appears that I'm not getting any injector pulse. Any help would be MUCH appreciated ( my mom seems to want to call every hour and ask if I figured it out yet )
-Brian
dieselphreak is offline   Reply With Quote
Old 02-21-2015, 02:34 PM   #2
CTScott is the man you need to hear from, but since he lives in the Northeast, he is probably out clearing snow.
Old 02-21-2015, 03:32 PM   #3
dieselphreak
Drives: 2009 yaris
yeah we are supposed to get some of that tonight too. However, in oklahoma you can't believe what they say, its sunny and 65 right now, high of 23 tomorrow...
Old 02-21-2015, 03:36 PM   #4
nortonfb
Drives: 2007
Did you pull the fuel line at the motor to make sure it's flowing?
Could be a filter.
nortonfb is offline   Reply With Quote
Old 02-21-2015, 05:47 PM   #5
It really sounds like the engine immobilizer is not happy and therefore not allowing the injectors to be driven. If the engine immobilizer light (on the dash by the windshield) is still flashing when the key is placed into the ignition, then the ECM is preventing the injectors from firing.
Old 02-21-2015, 06:07 PM   #6
dieselphreak
Drives: 2009 yaris
I dont believe this model has an immobilizer, no light on the dash like my camry, and no extra plastic hardware around the ignition
Old 02-21-2015, 06:51 PM   #7
OK. I always want to say that it was standard on 09+, but forget that it was part of certain packages.
Check the following:
20 A EFI fuse in the under hood fuse panel
At the injectors, with the ignition switch in the on position, remove the connector from injector #1 (closes to the belt) and check for 12V on the green wire.
If that is present, check the following:
If you remove the lower steering column cover (two screws behind the steering wheel, which are visible when it is rotated slightly and a third by the tilt wheel lever) you can access the ignition switch connector.
On it, check the following:
Yellow and Grey wires should have 12V with ignition off
White should have 12V with ACC on
Green and Pink should have 12V with IG in ON position
Black should have 12V while cranking the starter
Old 02-22-2015, 09:00 AM   #8
dieselphreak
Drives: 2009 yaris
Thank you sir! I will investigate this morning and report back my findings!
Old 02-22-2015, 11:51 AM   #9
dieselphreak
Drives: 2009 yaris
Voltage good, fuse good
12v present
all of the ignition wires checked out as well. Now I'm getting worried that it may be an injector driver issue in the PCM.
Old 02-21-2015, 08:08 PM   #10
bronsin
bronsin's Avatar
My 09 3 door basic hatch with auto....definitely no immobilizer!
Old 02-22-2015, 04:17 PM   #11
Try one more thing - Listen closely to the injectors while trying to start it to see if you can hear them clicking away.
Old 02-22-2015, 04:54 PM   #12
dieselphreak
Drives: 2009 yaris
Negative. No noise
Old 02-22-2015, 05:01 PM   #13
Negative. No noise
OK.
Also, check the following:
AM2 fuse (in under hood)
Put your ear against the plastic block that that fuse is mounted to and listen for the relays inside to click. When someone inside the car turns the ignition from off to on, you should hear two relays click.
Old 02-22-2015, 05:13 PM   #14
dieselphreak
Drives: 2009 yaris
That fuse is good, I also physically removed the integrated relay block and pulled them out and can physically watch them close also found out the third relay was the horn when I didn't see it close I used a toothpick to close it lol. The bruise on the back of my head should be gone in a few days lol
Old 02-22-2015, 06:49 PM   #15
I LOLed on that one. Nothing better than physical comedy.
So, it really does sound like the ECM is the issue. If you can get your hands on one from a same tranny type 07-09, you can verify that very quickly. If you grab an 09, make sure it too is a non-immobilizer one.
Since you don't have the immobilizer, there are no issues with swapping it. If you happen to have a manual transmission, I have a spare one on hand that I could program with you VIN and ship to you.
Old 02-22-2015, 08:51 PM   #16
dieselphreak
Drives: 2009 yaris
Its an automatic..
Old 02-22-2015, 11:36 PM   #17
IllusionX
Drives: 07 Yaris Sedan Aero
CTScott is really not the only one to LOL at the relay tooth picking. :)
Old 02-23-2015, 07:07 AM   #18
dieselphreak
Drives: 2009 yaris
yeah i'm 6'3" and was all hunched over that little thing, If i had a video it would be viral by now i promise that!
Hard start in the morning 2008 Yaris CE volks_r_us DIY / Maintenance / Service 9 03-09-2018 03:18 PM
2007 Yaris won't start. Camshaft sensor issue Countryman DIY / Maintenance / Service 14 03-11-2015 06:12 AM
Yaris and Viper 4204v remote start eeosman In Car Entertainment + Electronics (audio / video / alarm) 19 12-08-2013 02:49 PM
