#7 | |
Check the following: 20 A EFI fuse in the under hood fuse panel At the injectors, with the ignition switch in the on position, remove the connector from injector #1 (closes to the belt) and check for 12V on the green wire. If that is present, check the following: If you remove the lower steering column cover (two screws behind the steering wheel, which are visible when it is rotated slightly and a third by the tilt wheel lever) you can access the ignition switch connector. On it, check the following: Yellow and Grey wires should have 12V with ignition off White should have 12V with ACC on Green and Pink should have 12V with IG in ON position Black should have 12V while cranking the starter
| Hard start in the morning 2008 Yaris CE | volks_r_us | DIY / Maintenance / Service | 9 | 03-09-2018 03:18 PM |
| Do you like the 2012 restyle? | hitmoninfinity | Third Gen Yaris General Discussion | 106 | 04-14-2016 08:08 PM |
| 2007 Yaris won't start. Camshaft sensor issue | Countryman | DIY / Maintenance / Service | 14 | 03-11-2015 06:12 AM |
| Yaris and Viper 4204v remote start | eeosman | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 12-08-2013 02:49 PM |
