2ZR swap. DO IT! Ask how!
Cranky's 2ZR-FE swap
Coming soon to a rear bumper near me:
![]() This list is only for M/T swaps in a 2nd gen (07-10) HB! I've been driving with the swap for a few weeks now and want to post up some feedback. For comparison, I've had a Blitz supercharger installed on my 1.5 for about 4 years now, and absolutely loved it, right up to the point where it rendered the engine unusable. I never had it on a dyno, but similar setups reported upwards of 140 BHP. In theory the 2ZR is a downgrade, but it's not really apples to apples when you talk displacement vs forced induction. First off, I miss the sound of the supercharger. It would turn heads and blow peoples' minds when they found out what it was. The 2ZR has less "wow factor", but for me the OEM reliability counts for a lot more. The Blitz pulls much harder off the line, but the 2ZR has more consistent power up in the VVT-i range. All that said, I have to agree with CTScott's opinion that the 2ZR is in fact a better upgrade than forced induction. Some notes:
Shopping list
There are several smaller parts that I had to source because I only had a bare longblock. I can work on a list of those, but it's probably easier for you to just find an xD at a junk yard and strip the engine bay. Last edited by CrankyOldMan; 02-01-2017 at 10:16 AM. Reason: Removed shopping list, made more notes. |
Engine prep and assembly
I was able to find an almost mint engine, but the tradeoff is that it was stripped all the way down to the long block. No accessories, no mounts, hardly any hardware, most of the brackets and hoses were gone, too. I also don't have a ready supply of 09+ 2ZR vehicles to scavenge parts from, so I've had to buy or barter for a lot of the parts that would come with it if you pulled it from a vehicle yourself. ArmstrongRacing has been a huge help with sourcing some of the larger items, as well as confirming what parts can be reused from the Yaris.
I replaced the crank position sensor and oil pressure switch because they were damaged in the process of bringing the engine home. For reference, the 2ZR will just fit into the hatch of the Yaris, if you remove all the wire harness attachment brackets and EGR valve from the top. Last edited by CrankyOldMan; 08-04-2016 at 11:29 AM. Reason: Starting to assemble the parts |
Wiring, hoses, etc.
Throttle body
There are two different configurations for the xD throttle body: one that is like the 1ZZ and one with a vacuum port at the top (as installed). The vacuum line from this goes to the brake booster. If you have the 1ZZ style TB, you need the hose that goes to the port on the plenum below the TB flange. If you have the xD style, you need the hose that goes to the TB. *Pics to follow* Wiring The xD engine wire harness is almost an exact match to the Yaris' engine fuse/relay block connectors, with the exception of the MAF sensor power: pin 9 on connector CA2 (male) is missing on the Yaris. There are a few different ways to go about this, but I'm planning to use either an OEM pin from a salvaged Yaris fuse/relay block and a fuse tap, or one of the existing powered, un-populated fuse slots. The Yaris uses low-profile ATM style fuses, and the taps aren't usually available at auto parts stores. I got one from Amazon (Lumision) that has a right angle head and a second fuse slot to add your new device. If I go this route, I'll just splice in the pigtail and poke it into the connector. *EDIT* The other way is to use one of the un-populated slots. They're all powered from the bus side, you just have to insert a wire with the right connector to hook in a fuse. Super clean, no signs of aftermarket shenanigans. I took the wires out of a Yaris fuse box and found one that will work perfectly. I will use one of the empty fuse slots and populate the missing pin for the MAF sensor. Hoses Most of the hoses are application-specific, but the Yaris ones can be re-used if you're not concerned about odd bends or extra length. My engine was missing almost everything, so I bought aftermarket parts where available and new, OEM for the rest. Looking them up in the parts catalog is a mess, so I'll put up a list of parts at some point. The Yaris filler neck will not quite fit around the throttle body, and the hose from the radiator will be kinked. The xD filler neck mounts to the radiator instead of the TB, and uses different hoses. Accessories The alternator tension bracket was missing as well, so I just ordered new parts. It's the same as on the 2ZR Matrix/Vibe/xD, so you could get used ones from a u-pick yard. The alternator is the same as the 2ZR Matrix/Vibe/xD. The starter from the Yaris can be re-used, but preferably the cold-spec version. The xD is 1.8 kW - the standard Yaris one is only 0.8 kW, the cold spec is 1.8 kW. Connectors are identical, but placement is a little different. Power steering is electrically driven, so there's no pump to mess with. Air conditioning is optional. The compressor and short hoses are model-specific. Last edited by CrankyOldMan; 02-01-2017 at 04:57 PM. Reason: Added throttle body info |
Installation
The best thing to do is to get a 2 day subscription to the Toyota Tech Info site so that you can get the OEM repair manuals. Make sure you get the diagrams for ALL of the parts you're installing so that you have torque specs for the bolts.
Take a look at Brushforhire's thread for basic things that need to be done. The speed sending unit is most easily done by removing it from an existing Yaris wire harness, protecting it with wire loom/sleeves, and plugging it into the connector in the engine bay fusebox. The Yaris radiator shroud has threaded inserts for mounting the xD radiator filler neck. They will probably need to be tapped to clean up the threads, but it's well worth it to have the right parts in the right place. The upper hose from the Yaris is too short, you will need the xD hose. Tricky areas Getting the engine to line up with the mounts and clear the subframe didn't go so well. I put a nice gouge and a 6" crack in the windshield where the load leveler collided with it. Damn. I also pinched a CV boot in the process. The band was trapped between the subframe and the transmission, causing the grease to leak out. Damn damn. The radiator hose clamps are evil incarnate. I spent at least 2 hours trying to get the lower hose connected back to the engine. I don't know what Toyota expects you to do with these things. Lots of the wire harness brackets need to be swapped over, or otherwise improvised. Specifically, the one on the passenger strut tower and all of the ones on the gearbox. The immobilizer has to be dealt with. There is LOTS of confusing information in the OEM wiring diagrams that will really mess with your head. Proceed with caution. The Yaris shift cables are too short. The xD cables are a little too long. Better too long than short, I guess. I'm not sure where the problem is, since the shifter cages should be identical, and the gearbox cases are actually identical. Last edited by CrankyOldMan; 10-17-2016 at 09:09 AM. |
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
Very excited to see this happen! Congrats!
Really lookin forward to this build. This is what i'll be using as my guide when I eventually need a new engine.
To clarify, can you use a Yaris oem clutch and pressure plate? Or is the 2zr one needed for this work? I know the pressure plate is different for the 2zr but not sure about the clutch and pressure plate
![]() Drives: 08 yaris 1.8 dual vvti 5sp Join Date: Feb 2010
When I did the swap,I used a 09 corolla fly wheel and clutch assembly ,I originally wanted a celica gts 2zz flywheel and clutch assembly but ran out of money,settled for used low km corolla assembly, the splines on the input shaft on the yaris transmission are the same. But no I think the bolt pattern for the clutch is different on the yaris so it won't bolt up to xd fly wheel. PS if you have a factory immobiliser , you can't just use a non immobiliser ECU,won't start ,there is something in the body wiring harness.
About 2 years ago ,I think ,haven't really been on the forum lately until now.
#10 | |
Canada TRUMPS the United States (see what I did there)
Cranky: do you have an immobilizer? I'm wondering what the difference would be for parts if one does the swap w/ an immobilizer. I'm assuming needing an ECU with an immobilizer plus the correct wiring harness
In Canada most all Toyota's after 2007 came equipped with a immobiliser,I though initially it was just a matter of buying a American xd ECU with out a immobiliser but failed.(car no start)
After some research found that on immobiliser and non immobiliser engine wiring harness are the same but the body wiring harness is different,figure there is something in the harness that tells the engine ECU that there is a immobiliser ecu.didn't want to deal with dissecting harness so ended up changing engine ECU ,immobiliser ECU and keys( had to change second gen g keys). NOTE: if you doing the swap don't use yaris shift cables,there too short(they will work),The new mounts push the tranmission forward by 2 inches ,ended up ripping out the studs off the body which hold the cables,two holes in body had to weld the studs back in. |
#13 | |
Are the 2zr shift cables compatible?
#14 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Awesome! Glad to see someone documenting this swap with the Yaris C50 trans!
The "first US swap" We did was with a Xd manual trans and shift cables, so we didnt use any Yaris clutch components. I agree that using a auto trans harness is probably easiest, but you could also order a new manual trans Xd harness fron Toyota...I get a fat discount on Toyota parts so let me know if you guys need anything
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 04-16-2016 at 09:33 PM. |
#15 |
Data doesn't lie
lets see some pictures!!!
#16 |
All xd in Canada used a second generation immobiliser system so all the keys have a small G in graved on the key,my yaris had a first generation so it has a dot in graved on the key,couldn't get the old generation immobiliser to work with the xd ecu ,so just ended up getting a xd immobiliser ,xd computer and xd keys(chip is different). As for the shift cables yes xd cables are the only ones that work properly. It turns out the dimensions of the subframe are similar from what i figured,only difference is the xd subframe looks more reinforced,both cars even have same wheel base,so I also ended up using the xd sway bar as well ,it's thicker by a couple of mm.the distance of the sway bar is the same,both use same control arms ,knuckles and struts.so it possible to do a five bolt hub conversion as well ,only if you wanted to.
#17 |
The pictures are crap ,taken with crappy cell phone camera,also I don't have an Xd air box ,using a corolla air box for now.
#18 | |||||
![]() Drives: 11 GSE21, 86 AE86 Join Date: Apr 2016
Jeff
![]() 2011 Lexus IS350 6MT F-Sport with LSD 1986 Toyota Corolla GT-S Supercharged with TRD Stuff 2005 Toyota Yaris RS 5MT Short Track Car Last edited by Jeff Lange; 04-18-2016 at 06:27 PM. |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| My 2zrfe swap | brushforhire | Performance Modifications | 131 | 06-08-2016 09:43 PM |
| 1nzfe throttle body swap and fitment questions | EchoBob02 | Performance Modifications | 14 | 05-01-2014 08:02 AM |
| FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) | AdeJong 03 | Items for Sale by private party | 4 | 04-05-2010 11:25 PM |
| Gauge Cluster Swap, other interior swap questions. | Adrenalingirl_K | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-09-2009 03:32 AM |
