![]() Drives: 08 yaris 1.8 dual vvti 5sp Join Date: Feb 2010
In Canada most all Toyota's after 2007 came equipped with a immobiliser,I though initially it was just a matter of buying a American xd ECU with out a immobiliser but failed.(car no start)
After some research found that on immobiliser and non immobiliser engine wiring harness are the same but the body wiring harness is different,figure there is something in the harness that tells the engine ECU that there is a immobiliser ecu.didn't want to deal with dissecting harness so ended up changing engine ECU ,immobiliser ECU and keys( had to change second gen g keys). NOTE: if you doing the swap don't use yaris shift cables,there too short(they will work),The new mounts push the tranmission forward by 2 inches ,ended up ripping out the studs off the body which hold the cables,two holes in body had to weld the studs back in. |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| My 2zrfe swap | brushforhire | Performance Modifications | 131 | 06-08-2016 09:43 PM |
| 1nzfe throttle body swap and fitment questions | EchoBob02 | Performance Modifications | 14 | 05-01-2014 08:02 AM |
| FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) | AdeJong 03 | Items for Sale by private party | 4 | 04-05-2010 11:25 PM |
| Gauge Cluster Swap, other interior swap questions. | Adrenalingirl_K | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-09-2009 03:32 AM |
