Old 11-26-2006, 08:36 PM   #1
atebit
Drives: 07 Yaris Sedan
No AM radio signal on two aftermarket HUs?
I've tried two different model Alpine HUs in my 07 sedan, and have noticed in both cases that AM radio reception is pretty much non-existent. FM radio comes in strong/fine, so I don't think it's a case of a bad windshield antenna connection to the radio.
I originally had the "integrated" AM/FM/CD stereo in the car. I'm almost starting to wonder if the factory radio had a built-in AM loop antenna or something like that, instead of it using the windshield antenna? The only other thing I can think of is maybe there's a separate feed for the AM antenna on the wiring harness that I wasn't aware of.
Not having AM isn't a huge deal...99.995% of the time I'm listening to either XM or the iPod, but in my area there are some decent AM news stations that I listen to every once and a while. Has anyone else had an issue with AM (or even tried to listen to AM) after replacing their stock HU?
atebit is offline   Reply With Quote
Old 11-26-2006, 09:18 PM   #2
enkid
Antenna
The antenna is in the rear glass. It is a powered antenna, and there is fair FM reception when unpowered. It could be that the current capability of the Alpine power antenna wire is too low. You may wish to try connecting the Yaris power antenna lead (Socket A pin 8) to the accessory lead (Socket A pin 3) instead of to the alpine blue wire. If your AM reception comes back, you may either leave it as is, or have the alpine turn on a relay to connect battery power to the antenna.
enkid is offline   Reply With Quote
Old 11-28-2006, 09:18 PM   #3
atebit
Ah...I didn't realize it was a powered antenna. My strong guess is that the power lead for the antenna isn't connected at all. FM reception is pretty good, so that much certainly bodes well with your theory. I'll have to yank the HU & check out the wiring...sounds like an easy fix.
Thanks for the info...I would have never guessed it was a powered antenna!
Old 11-30-2006, 12:23 PM   #4
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
Question
Does anybody know if the hatchback(liftback) also has a powered antenna? I don't get any AM reception in my car with an aftermarket deck.
If it has a powered antenna, which coloured(colored) wire on the Scosche wiring adaptor do I connect the powered antenna wire from my deck to?
Thanks,
earljail
earljail is offline   Reply With Quote
Old 11-30-2006, 01:16 PM   #5
redbluff
Thanks,
earljail
Same issue for me. Very poor AM recepton on the hatch back and not real good FM. Using an aftermarket radio. Called while it was under warranty and had them send me a new one. Put it in and does the exact same thing.
The hatch antenna is powered. How do we all know if we connected the wires correctly for the amplifier on the antenna to work?
redbluff is offline   Reply With Quote
Old 12-01-2006, 10:07 AM   #6
jbll
Drives: Yaris HB 2007
I have the exact issue with my HB and Alpine Head Unit with FM reception
didn't try AM...
What do the power antenna change to the FM reception?
And btw, my reception was VERY good with my Toyota Heand Unit...
I tought the power antenna cable was for the antennas which go up and go down all alone....
jbll is offline   Reply With Quote
Old 05-25-2014, 04:20 PM   #7
bobdawonderweasel
Drives: 2007 Yaris sedan
Confirmed on a 2007 Yaris sedan that the antenna amp needs power.
Scosche Radio Wiring Harness for 1987-Up Toyota Power/4 Speaker Connector
to
Kenwood Excelon KDC-X598 CD Receiver
I was having radio reception issues and connected the Blue wire on the Sc osche connector to the White/Blue wire on the Kenwood.
As soon as I powered on the unit my AM reception was working and the FM signal was strong.
The original radio was the factory integrate mode. It fried about a week ago. I did a bunch of Googling to see what I could replace it with. That's when I found this site. After using the Search function (yes I actually used it) I was able to install the new radio quite easily.
This last little glitch with the reception was the last outstanding issue.
I did solder all my wires and heat shrank them rather than use crimp connectors. I should note that I worked on avionics in the Air Force (B-52's and KC-135's) and have no fear of soldering and a working knowledge of wiring diagrams.
Thanks to everyone on Yaris World for your posts!!!
bobdawonderweasel is offline   Reply With Quote
Old 12-07-2006, 04:49 AM   #8
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
Well at least Toyota doesn't use something like Nissan's Diversity Antenna... I have a rear-window printed antenna AND a power post type antenna, apparently the head unit decides which one is getting the best reception and switches, it's a real nice headache for aftermarket, as if my car's built in Bose Audio system's balanced-line signal output and odd impedences weren't bad enough.
paultyler_82 is offline   Reply With Quote
Old 11-24-2012, 08:32 PM   #9
auxmike
auxmike's Avatar
Hmmm.. I'm experiencing the same misery with a 2013 Tc deck in my '08 hatch. No AM! as a talk radio fan I need it...
The 2013 deck needs an adapter cable to work on the '08 antenna plug. There is a powered wire for the antenna coming from the antenna adapter. So which color harness wire would I need to tap into to juice up my OEM antenna then? Can I just use a squeeze on wire tap instead of cutting?
Old 07-23-2013, 07:33 PM   #10
2005vitzRS
2005vitzRS's Avatar
Drives: 2005 Vitz RS, NCP91, Manual
I'm having similar problems and have written about it in this thread.
http://www.yarisworld.com/forums/showthread.php?t=46256
If anybody has a solution please let me know.
Cheers
2005vitzRS is offline   Reply With Quote
Old 09-13-2014, 12:18 PM   #11
Potato2012
Drives: 2012 Toyota Yaris 4dr
I had a general question regarding antennas and radio. I have 2014 Toyota Yaris LE and the AM/FM signal is awful. I had it to taken to Toyota and they said there was nothing wrong. Any suggestions? They said there was nothing wrong because there is decent signal in the city for them to tap into. My father owns a 2006 Dodge Dakota and I can tune in my usual radio station from home to work no problem and my Yaris is fuzzy and terrible until I reach the city limits so there is definitely something wrong. Hope someone has some insight.
Thanks
Potato2012 is offline   Reply With Quote
Old 09-30-2014, 10:35 AM   #12
tomkecil
Thanks
It sounds like your signal amplifier isn't working. To check that it's getting 12V to it, pull the radio out and check that the all black lead in the middle of the blue plug on the Yaris harness is getting 12V fed to it. The antenna is part of the rear window and without amplification the signal will be poor. When working properly, the Yaris antenna + amplifier gives a better radio signal than any other car I've seen.
tomkecil is offline   Reply With Quote
Old 10-08-2014, 05:15 AM   #13
nookandcrannycar
On your 2007 sedan. Potato2012 has a USDM 2012 LE. Potato2012's model has a roof antennae .
Aftermarket Stereo / Speaker Specifications bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 93 10-20-2022 04:38 PM
Toyota AUX plug w/ aftermarket radio? eight_heads In Car Entertainment + Electronics (audio / video / alarm) 20 09-07-2007 03:41 AM
Turn signal audible alert paultyler_82 Performance Modifications 7 10-01-2006 11:21 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 02:13 PM
Sirius Radio YotaYarisUSA In Car Entertainment + Electronics (audio / video / alarm) 4 03-21-2006 05:41 PM
