N/A?
Are there anymore options for N/A power? i did the I/H/E(Axleback) &Pulley.I am sitting on about $300 with nothing to gear it toward
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
1ZZ-FE throttle body. I think they go for $60, at least that's what i got mine for. Also you may want to get the Nitto mid-pipe, it would complement the axle back real nicely. Should see a lil' more power with those two mods and what you have
did you notice a power increase or just a lost of tq down low? think i might drive 2hours to get my car dyno today after i get off work at 2pm
What?
How do you drive your car? There's probably some more top end power to be gained by replacing the exhaust between the header and axle, but it's probably only going to show up above 5500-6000 rpm. In the real world, that just translates to numbers. "My car makes 100 whp on the dyno". Big deal. Unless you're drag racing, mid-range torque and throttle response is far more important.
If you're looking for more "daily driving" torque, about the only thing left to do is a lightweight flywheel and start shaving weight from the car. |
#5 | |
Soo you sayin i would need a mid pipe? do they make one for SD? Removing the seats are not practical for me tho i like the idea. Just looking to make some N/A power before i go FI a couple months later
#6 | |
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
R-CaT Project Yar 2ZR |
37HSSV
Trust me, removing rear seats and getting rid of useless junk from the rear, definatly makes the car feel faster.
In my case, I removed nearly 100lbs from the back because of my 60/40 split seats. Saved maybe 6 lbs total by replacing the front seats with racing seats. It all adds up.
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
#8 | |
Exactly
Learn to Relax
Exactly
What?
If your plan is to go FI, why not be patient and spend your $300 on something like a wideband O2 sensor rather than on something that might maybe net you 3 hp for a couple months?
.... you are right. Lets change that months to a year+ later lol
Who said Yaris was slow?
No need to go drastic on the weight shaving area...
Taking the rear seat out and installing them out is a matter of 15 min. Is not like you won't be able to seat anyone on the back of your car ever again... ![]() I've taken mine in and out about 3 times now. If I know I won't be carriying anyone for a while I just take them out. Is really easy. If you have the 60/40 rear seats... those are REALLY heavy! When I go out for a spirited drive I even take out the spare tire and jack (If I'm not going too far away from home )You can definetely feel the difference.... When I remove the back seat and spare tire I have to adjust the rear coilovers as the car will raise the back like 1/2 or more...
Touge Driver
"I drive my yaris like i had stole it!"LOL
If you install the 1ZZ-FE throttle body, do u need a piggy back or any ECU changes??? |
Nope after installing it just let the car idle for a little bit and it should re-learn the new throttle body. This is the case if you swpped over the chip that's in the TB as well. Really cheap mod $60 shipped. Hopefully you can find one for that cheap. don't know how much they go for on ebay
HOW MUCH OF A DIFFERENCE IN SIZE ARE THERE BETWEEN THE 1NZ &1ZZ THROTTLE BODIES. HOW MUCH POWER DIFFERENCE CAN BE SEEN?
dont yell, we can all hear you.
![]() I think its almost a 1" difference, I have it but I havent measured it. |
#18 | |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
Stock 1.5 1ZZ 2.5 I have some pics but I' am not uploading them just to see that's 1" bigger
I Drive a 129whp Yaris ;) |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 02:12 PM |
| Viper Alarm Install | gwasabi | In Car Entertainment + Electronics (audio / video / alarm) | 28 | 08-11-2010 02:57 PM |
| N/A stage 1 upgrade? | forpinks | Performance Modifications | 12 | 03-18-2007 08:42 PM |
