Old 06-04-2009, 04:27 AM   #1
curtqn
Drives: Toyota Yaris
Change Engine Coolant
I want to chane the radiator coolant of my 2009 Toyota Yaris. I got under the car and look up. Behide the engine to the right I see a little bolt with a valse comes out. Is this where to let the coolant in the engine comming out ?
Thanks.
curtqn is offline   Reply With Quote
Old 06-04-2009, 04:31 AM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
There's a little white plastic wing nut looking thing on the
back of the Radiator at the bottom.
Old 06-04-2009, 09:00 AM   #3
MadMax
MadMax's Avatar
If I may ask, why are you already changing the coolant in an 2009 Yaris?
Old 06-04-2009, 09:13 AM   #4
1stToyota
1stToyota's Avatar
Thanks.
2 drain points: Radiator and back side of block.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 06-04-2009, 09:48 PM   #5
curtqn
1stToyota:
Thanks for the reply. Where is it located on the back side of the block.
If I just drain the radiator alone. Is it OK?
Old 06-04-2009, 11:16 PM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
You won't have completely drained and changed the coolant if you do that.
Why do you want to change the coolant on a new Yaris?
Old 06-05-2009, 05:13 AM   #7
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
If you just drain the radiator you are probably getting only half the coolant as the other half is still in the engine.
Also curious why the need for a coolant change when the coolant from new should last at least till 50,000 , most people never change it till the car starts overheating at about 180,000 and a new radiator is required.
Old 06-05-2009, 05:41 AM   #8
texkid
The one with cheese on it
Drives: '10 Corolla S
Is it just me or is it odd that three members have asked the same question but the OP still hasn't answered it? Hmmm....
texkid is offline   Reply With Quote
Old 06-05-2009, 09:41 AM   #9
1stToyota
1stToyota's Avatar
1stToyota:
If it's just a drain and refill (w/ a 50/50 mixture) draining just the radiator is okay. But soon as you start flushing the system you won't be able to get enough straight coolant in the system with just a radiator drain. And the block drain is roughly in the middle of the block...crack open the bolt and fluid will come out of what looks like a little faucet.
2008 Scion xD
Old 06-05-2009, 10:18 AM   #10
mrbond
mrbond's Avatar
I agree - it's wayyy too soon to be changing your coolant. Unless you've thrown a turbo in your car running high boost and you want to put in better performing coolant, I'd just stay away from it until you need to get it taken care of.
- A Toyota Yaris
- A whut Yaris?
Old 06-05-2009, 11:01 AM   #11
auxmike
auxmike's Avatar
Let's try again; why are you changing antifreeze on a brand new car?
Might be a troll under the bridge boys.......
Old 06-05-2009, 11:35 AM   #12
MadMax
MadMax's Avatar
Must be, he seems to have done a post-and-run...
Old 06-05-2009, 11:48 AM   #13
YarisSedan
Drives: 08 Yaris Sedan
Coolant on our vehicles are designed for 100k for the first change and 50k every change afterwards. You need to make sure you purchase toyota only coolant as it is specifically designed for our cars and radiators. You also need to premix it with a 50/50 of distilled water.
Draining from the peakcock valve on the radiator will only get approx half of the coolant out of the motor as some is going to be left in the hoses and engine block. Proper way to be using a coolant flush machine that gets all the coolant out and puts all new coolant in. Something that any service shop can do.
Old 06-05-2009, 12:15 PM   #14
bronsin
bronsin's Avatar
Just a FYI here. On my ECHO I used to change the coolant by using only the radiator drain. I measured the ammount that came out and it was what the book said was in there. Probably.....the Yaris is the same. In any event do not make a habit of letting others (especially the dealer!) work on your car. IQs have dropped sharply in the country in the paast few years. All they know is how the screw it up nowadays.
Old 06-05-2009, 12:56 PM   #15
1stToyota
1stToyota's Avatar
...provided that they have their tank full of pink fluid, otherwise they'll probably consider the *global* coolant as the only coolant you should use.
2008 Scion xD
Old 06-05-2009, 03:39 PM   #16
jambo101
jambo101's Avatar
Could be a certain some one moved from the southeast to the southwest. Or maybe the guys a busy fellow and just hasnt got back to his post.If he has a Yaris he'll be back.
Old 06-05-2009, 08:51 PM   #17
Yaris Hilton
Smile
...the peakcock valve...
OT, but that reminds me of the three stages of men. Young men have a petcock. As time goes by, it turns into a draincock. (I suppose that could also be called a peacock. Think phonetically.) With old age, it becomes a stopcock.
Old 06-05-2009, 10:09 PM   #18
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
^^^ And then there's the much dreaded cockblock that happens around the time a man gets married.
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
Coolant level when engine cold CB900F2 DIY / Maintenance / Service 4 04-05-2009 12:12 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 01:51 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 01:26 AM
