![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
09 Fog Light Install
I just want to make sure I'm doing this right before I finish so I don't have to tear everything apart again. I'm installing Micro Image fogs ( http://shop.microimageonline.com/pro...&productId=103 ) in an 09 LB and will be using the OEM stalk, not the supplied switch. I followed the supplied Toyota installation manual and I think I have a bit of a problem. Step #12 shows 2 wires (red/brown & red/white) connecting to pins 1 & 2 in the fuse panel but.... the wiring harness I received has 2 solid red wires. Does it matter which wires goes to which pin?
I used the headlight ground (near the air cleaner assembly) to ground the fogs and plugged in the supplied relay under the dash. Am I correct in assuming all that's left for me to do is install the OEM stalk? No more wiring necessary? |
![]() ![]() Drives: 2008 Red Yaris LB Join Date: Nov 2008
You don't want your switch? I'll pay you for that since mines is busted up.
I have the switch and the whole in-cabin harness. How much?
I only need the switch, I already have my fogs installed
Ok make me a reasonable offer for the switch and it's yours
check pm
#7 | |
Don't forget about the FOG fuse as well. Other than that and the stalk you are good to go. |
Is it a problem if I used both wires/pins?
Ok good to know. Next up is the fog & cruise stalk and leather steering wheel
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 09:47 AM |
| Part #s for Fog Light install? Can anyone who works for Toyota confirm? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 73 | 12-23-2010 06:15 PM |
| Fog light install | 07yaris_fe | Cosmetic Modifications (Exterior/Interior) | 10 | 07-20-2010 02:18 PM |
| Looking for the Toyota Fog Light install | RocknRollRon | DIY / Maintenance / Service | 33 | 06-13-2010 07:46 PM |
