Old 10-02-2009, 03:05 AM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
What's wrong with my tach?
So I got this SunPro Mini Super Tachometer II and installed it a couple of months ago. Everything went fine, got illumination and all.
After a while I started noticing that sometimes the needle wasn't moving when it should have been... So I kept an eye on the problem. Here are the observations I made so far.
If I turn the key (switch off the engine) too quickly, the needle remains at whatever RPM there was when I started turning the key. If I stop at in the ACC position I can wait for the needle to (slowly - 1-2 secs) come down to zero. I don't know if that makes a difference for the actual problem described below.
Symptoms:
- I turn the key from OFF to ACC, the needle jumps from zero (or wherever it is) to 1 (1000 RPM) even though I haven't started the engine yet.
- When I actually start the engine, the needle jerks a little, but remains stuck at 1. No matter how I rev the engine, the needle doesn't move.
- I shut off the engine, turn the key back all the way, the needle goes down to 500 RPM and stays there even if I take the key out.
- Usually during my 25-30 min commute, the tach eventually starts working correctly. I never caught the actual moment and how it happens, but I just at some point notice that everything is alright.
Does anyone have any ideas? Theories? Has anyone experienced anything similar? I have no idea what could be wrong? Some kind of static charge built up somewhere? No idea, just guessing here... I tried tapping, light and hard, it didn't help.
fmicle is offline   Reply With Quote
Installing Speedhut tach, need help! RedRide DIY / Maintenance / Service 2 07-05-2009 05:02 PM
need a 2" tach, like the cobalt from autometer severous01 Cosmetic Modifications (Exterior/Interior) 0 04-20-2009 09:55 PM
Tach Installed & Temp Wheels On justjesus Off-topic / Other Cars / Everything else Discussions 4 02-07-2009 02:26 AM
Installed Tach...Tach works, RADIO doesn't! 5spBlazer DIY / Maintenance / Service 17 08-06-2007 09:57 PM
How to install tach? charles nelson DIY / Maintenance / Service 1 08-04-2007 12:34 PM
