Old 11-07-2006, 10:20 PM   #1
BMGYaris
Drives: Yaris 3dr Hatchback
Engine breaking
hey i was doing some test today and found that on a straight flat road if go about 45-50 mph steadily, then let go of the gas i will drop to 30mph in about 8 seconds. I have an automatic. Is that normal? i also found that on moderate hills i actually slow down going down them. Normal? if not what could be wrong?
Tire pressure is A-OK and no, the engine break was not engaged
(sorry to all of those tired of my stupid topics...)
BMGYaris is offline   Reply With Quote
Old 11-07-2006, 11:01 PM   #2
ChinoCharles
Drives: LB
What gear were you in? That is what matters... in third gear the car will come down pretty quick from 45-50. In fifth it won't. I'm guessing you were probably in fourth gear. Actually, on an automatic, you can improve gas mileage by going a little over 50 until the car settles into fifth, and then when you slow down 5 mph or so the car should stay in fifth. At those speeds on a flat/downhill surface, you'll get the best mileage in 5th gear.
Old 11-07-2006, 11:11 PM   #3
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
He has an automactic so that means there's only 4 gears (for the Yaris) the 4th being the overdrive gear.
Well there's two reasons I can think of, since the Yaris has a gated shifter (for auto) you might have accidently have the shifter in 2 or 3rd. I remember when I test drove the sedan I thought I was in drive but I was 3rd! Luckily I wasn't going that fast. Otherwise if your car was cold (meaning the engine/tranny) the car won't upshift into the overdrive gears (4th) until its warmed up. Don't worry this is normal. From my understanding its emissions reasons, cause when the engine is cold it produces more emissions! So to warm it up faster the car was design to not go into 4th until its warmed up. Make sense?
Engine breaking is ideal when you need more power (going up hill or pulling something but don't recomend that with the Yaris as it wasn't designed for that) or going down hill so you don't ride the breaks. But idealy for the best economy and less wear and tear on the drivetrain stay in drive. Hope that helps and there's nothing wrong with your car! Keep us posted!
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 11-07-2006, 11:24 PM   #4
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
It's all completely normal
When going down a moderate hill and the car slows down on it's own it just means the cars speed is faster then the set throttle position. Basically you are still going the same speed but with no throttle.
The joys of drive by wire....
Also how much engine/trans breaking is applied had to do with how much or little load is on the car, engine rpm and the speeds the car is traveling.
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 11-08-2006, 03:08 AM   #5
ChinoCharles
Drives: LB
4 speed auto, eh? Who knew? Oh, right... everyone but me.
Old 11-08-2006, 03:22 AM   #6
whoguy
Drives: Yaris YRS Sedan
Actually, in the brochure I got, the Yaris automatic is actually designed to slow you down when you let off the gas, especially when going downhill....an added feature.
whoguy is offline   Reply With Quote
Old 11-08-2006, 04:49 AM   #7
Hmm that's good in a way, one thing I really don't like about most automatics is the lack of an engine brake!
Old 11-08-2006, 05:57 AM   #8
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Oh my God, by reading the thread's title I thought that someone actually broke his engine!!!
Old 11-08-2006, 06:46 AM   #9
IsLNdbOi
IsLNdbOi's Avatar
That's good to know! I thought something was wrong with mine everytime I felt it slowing down (sometimes feels like I pressed on the brake even when I hadn't) when going downhill and even when I'm coasting.
Old 11-08-2006, 06:58 AM   #10
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Engine Braking
It takes a little getting used to but it is completely normal. Next time you are going downhill at highway speeds, try tapping on the brake a little. The computer will apply even more engine braking. It is really a smart little car.
Old 11-08-2006, 09:07 AM   #11
BMGYaris
WHOOOOOPS about the breaking id like to say it was late but it was only 11:20pm...so...i'll go with the excuse that i only slept 2 1/2 hours the night before....
Anyway, thanks for all your responses, i guess that is ok then. but just so anyone who reads this knows, i was going 45 (thereabout) on a straight road for about 15-20 intentionally keeping it steady and stable at those speeds for the experiment. And i have done my homework pretty well at this point, def was in D, i let go of the gas and it dropped as stated above. Nothing in the car but me, though i do way 200 lbs and the car was warmed up.
who else would like to see these two combined?
Old 11-08-2006, 09:58 AM   #12
Katana
Katana's Avatar
Let me tell you something that happens on manual gear box, on 2nd gear.
When I am going at about 25km/h and I have 2nd gear, if I stop pressing the gas pedal, the car goes like crazy(going front and back!) as a result of the engine breaking.So don't worry about it!
Engine mods - why bother? RallyYaris Performance Modifications 143 12-24-2006 03:56 AM
Q about Routing wires to the engine compartment W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 10 11-01-2006 07:36 PM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
Engine Working too hard? David81 General Yaris / Vitz Discussion 8 06-14-2006 11:17 AM
Noisy Engine David81 New YARIS Purchase Forum 8 06-02-2006 12:15 PM
