![]() ![]() ![]() ![]() Drives: Yaris 5 door liftback Join Date: Jan 2009
Longer Life Oil Filter?
Claims to filter oil so well you will need fewer changes.
From the web site: http://www.electrolubegreen.com/home.html "Electro-Lube Green Since 1977, an industry leader in bypass oil refiners, Electro-Lube’s proven technology is the product of decades of development and operation with thousands of installations on five continents. Based on the proven fact that motor oil never wears out, it only gets contaminated or its additives get depleted, it stands to reason that if we keep it clean and free of solid particulate matter and undiluted by water, diesel fuel, glycol coolants and highly corrosive acids, lubricating oil will retain its physical and chemical properties almost indefinitely. This results in permitting greatly extended oil change intervals with substantial savings for anyone who operates internal combustion engines or industrial machinery. Electro-Lube Refiners filter out solid particles down to 5 microns, while original equipment filters on the engine will only effectively remove particles of over 30 microns in size; 60% of engine wear is caused by particles smaller than 30 microns. It traps and neutralizes acids, keeps water content to less than 0.5% and fuel dilution to less than 1%. It helps prevent sludge which forms when dirty oil is too saturated to carry away all of the waste products it has cleaned out of your engine. Since Electro-Lube is a bypass refiner, it cannot block the flow of oil to the engine although it will greatly prolong the service life of the original equipment full-flow filters that come with the engine. Major engine manufacturers are on record as saying that although they make no claims for after-market installations, a correctly installed Electro-lube by-pass refiner system will not affect their new engine warranty." |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 08:18 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 02:55 PM |
| Nippon Oil Filter | IllusionX | DIY / Maintenance / Service | 6 | 12-07-2008 03:00 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
