Old 04-05-2009, 11:47 PM   #1
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
1nz-fe intake manifold , Xa ...
Been looking for more performance from the yaris as I have all the basic bolt-on parts . Been searching scion life and found that Weapon R make a very nice intake manifold that fits the 1nz-fe that found in the Xa . I know it will match the head ports and bolts but will probaly need modify the intake as it changes the angle and not sure of the differnce from the Xa tb bolt pattern and the yaris Tb bolt pattern . Discuss...
http://www.scionlife.com/forums/view...ntake+manifold
Old 04-06-2009, 12:17 AM   #2
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
they look nice... So this will replace the stock plastic ones we have on the yaris, right?
Old 04-06-2009, 12:56 AM   #3
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I think they only made a couple and scrapped it IIRC but other than the angle of the TB it should work.
Old 04-06-2009, 12:57 AM   #4
PHXDEMON
PHXDEMON's Avatar
I'm not 100% sure if the angle of the TB is even an issue actually.
Old 04-06-2009, 01:10 AM   #5
^ correct, not directly compatible without modification.
Old 04-06-2009, 10:33 AM   #6
with good metalworking knowledge/a good fabricator, one could quite easily chop off their TB flange and weld on one suited for ours...
I'm not sure these would give as much gains as the legendary magical elusive Holderner IM, but at least it's actually available, which is always a plus...
Old 04-06-2009, 11:14 AM   #7
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
maybe its just me but does the welds look kinda crappy?
:-/ It may be excessive but they are good welds.
Old 04-08-2009, 12:21 PM   #8
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
+1. TIG isn't easy. It takes a while to make beautiful welds.
Old 04-06-2009, 11:16 AM   #9
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
i'm wondering why weapon-r chose to go with two sections of pipe welded together rather than bending a single pipe. i'm sure the radius isn't too small to bend, since it's often done.
Wanted: Forced Induction
Old 04-06-2009, 11:42 AM   #10
mrbond
mrbond's Avatar
Those welds are outta control. They may be technically good, but they just look awful. I'm comparing these welds to those of Fujitsubo and TRD items, though. Geez.
- A Toyota Yaris
- A whut Yaris?
Old 04-08-2009, 08:16 PM   #11
Crandall
H8R
Crandall's Avatar
Drives: 08 White RS
So you'll take visually pleasing over quality? Interesting.
Good luck with that.
Old 04-06-2009, 12:29 PM   #12
at3GG
at3GG's Avatar
Drives: 07 metmet LB
so should a good mufffler place be able to make this fit?
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 04-06-2009, 12:30 PM   #13
Nexus1155
Drives: Audi
I think the weapon R ones were done by hand while others were machines?
But it was welded in two pieces because think of it. You make the box itself, then you weld the first section of pipes on, go to the intake flange weld the second, then join them together. It's alot easier to mockup like that for the person who is doing them vs. needing a jig/clamps etc to have one whole piece.
Even a couple of holdeners welds were in seperate sections?
Old 04-06-2009, 12:39 PM   #14
holdener had them in separate sections to make the prototype easier to work on, yeah. Like you mentioned, they probably did each half separately then joined them. I'm no welder but I can imagine it's not easy to get into the tight space on the inside of the bend...
Old 04-08-2009, 07:50 AM   #15
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
http://weapon-r.com/english/index.ph...oducts_id=5546
found it
Old 04-08-2009, 08:28 AM   #16
PHXDEMON
PHXDEMON's Avatar
Originally Posted by AlexNet0 View Post
This product will be in stock on Friday 25 December, 2009.
Old 04-08-2009, 05:38 PM   #17
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
TIG is simple for me yet it took about 3 years of practice to get it right. They originally made an intake with straight runners to a box and it didn't yield any gain this is there new attempt.
Ever blown out an R-200 diff god know's I have
ztrack157 is offline   Reply With Quote
Old 04-08-2009, 06:24 PM   #18
Nexus1155
Drives: Audi
yeah the one that goes straight to the box would never yield gains in something like this, you need to calculate the runner length which is probably what they didnt do the first time around, it takes alot of physics to get these things right! lol
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Matrix 1.8 intake manifold dallas Performance Modifications 4 03-28-2009 01:42 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
