Old 03-28-2009, 12:31 AM   #1
dallas
Drives: Yaris Hatch /Landrover D2
Matrix 1.8 intake manifold
I went looking for a larger throttle body today from a 1.8 I found one still mounted on a 2007 Matrix manifold. I did not have the manifolds side by side but it sure looks simular to the 1.5 manifold on the Yaris. That got me thinking would it work on our cylinder heads and maybe provide more flow, or is it even the same? I'm tempted to buy it to compare. What about the heads on those two engines are they the same castings ?, Could we use the short block 1.8 to increase displacement ? I'm going to look into this further, if anyone can shead some light let us know.
dallas is offline   Reply With Quote
Old 03-28-2009, 01:01 AM   #2
well the blocks are completely different (NZ vs ZZ), so swapping them would not be possible, but the intake manifold, maybe, who knows, might get lucky, if you can get your hands on one, give it a try!
Old 03-28-2009, 01:20 AM   #3
dallas
Thanks, that's what I thought but was not certain, in my old school "daze" of building Datsuns they had 1.6, 1.8 and 2.0 and there was a lot of interchagability between blocks heads, cranks, and pistons etc to yield higher compression ratios etc. Do you know if the cylinder heads are the same?
Im tempted to get the intake to compare the flange if it's the same, I will fill both with measured amounts of water to see if one has more internal volume, and may perform better. Why just change the throttle body if a manifold with more volume may work! We could call it the low cost "Holdner"
Old 03-28-2009, 01:35 AM   #4
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
LOL
I would try this but my wallet does not accommodate it this month or next month.
http://cgi.ebay.com/ebaymotors/TOYOT...ayphotohosting
Old 03-28-2009, 01:42 AM   #5
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
the bolt holes my line up and if they do maybe a little porting will do you good.
Ever blown out an R-200 diff god know's I have
ztrack157 is offline   Reply With Quote
intake manifold photo richardholdener Performance Modifications 94 08-04-2009 01:25 PM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
